(Storage) SSD Discussion Thread
xonix
How much is the Strontium Matrix? :s11:
Strontium online store having promo @ 220 USD
Favourable review at VR Zone: http://vr-zone.com/articles/strontium-gamma-115gb--matrix-120gb-ssd-review/12848-6.html
Leaning slightly towards Intel despite slightly slower speeds compared to the other 2 models due to:
- generally good rep for reliability
- 5 yrs int'l warranty
- retail pack comes with mount kit
- future firmware support?
Positives for Strontium from my POV is only faster speed @6gb ( and support for local manufacturer? :o)
adrianlee
IntelligenceA
hi guys,
i am intending to upgrade my asus laptop 2.5" SATA hdd with ssd. budget is around 200++ sgd, for an above 100gb ssd. Can any recommend any reliable (in terms of data retention, customer service, write/read speed also, but secondary concern) brands for me to start reading up on?
thanks!
cscs3
Imagine assembled here, shipped to US, and we buy from US, they ship all the way back here again! So why is it that prices here are higher than in US???
Simple, write to the factory, told them you want to order 100 unit and 10,000 unit. Then find the price different.
Webbyboy
hi guys,
thanks!
get crucial 128gb from linkecomputer about $280.
adrianlee
ki113r
Just got my system running with my new crucial m4 64gb. But it starts up only in 1 min :( What should i do to improve it?
DellSuperman
What's your bootup time before..? If before was 3mins, than I think 1 min is good enuf.
And try removing excessive startup program, it should help.
And I am not sure about the exact standard in which the time is being measured. I heard some saying that the time only starts when the first Windows animation appears & ends when your desktop is ready for use.
ki113r
Thanks for the reply Superman :D
This is the boot up time of my system with WD VelociRaptor 150GB. I just installed windows7 on my ssd, so there should not be excessive startup program?
DellSuperman
Hmm, did you do a fresh install or a harddisk clone?
For me, changing from HDD to SSD created a huge difference in the bootup time. Might be because my old HDD is really quite old & slow.
ki113r
I did a fresh install leh. Installing was FAST compared to a normal HDD. I'm going to try update the firmware to see if it helps. What do you think?
Solkarnar
Are you including POST? The ssd only helps with windows/program loading, it wont help the POST process.
