Huawei Honor U8860 non camera Users come in
Espedine
Hi guys want to check with you guys, i've followed the instructions for MIUI until the part where going to install the update.app from the dload folder where by you press both volume keys and power button. I keep getting a pink screen instead of the update anyone can help me?
ps its stuck at the step where im trying to access to replace the recovery.img file in the root
agentxq49
at the pink screen, connect your phone to the computer, then it should show up as a disk drive, where you can replace the recovery.img file.
then battery pull and press vol + and power to enter recovery.
xonix
The current sets back cover still has the cut out for the camera lens?
Espedine
i read ICS denied pink screen as usb drive leh, then the IMUI still suggest to install ICS first, now my computer cant detect the USB drive in pink screen. I've used root explorer to replace the recovery.img currently cant boot, when try to go into recovery give me error in my recovery.img.
ps: im following the instructions from IMUI, using the recovery.img from IMUI, need help please! :(
nannoid
You need B919. That version of ICS allows custom recovery.
kaefert said:
MIUI 2.6.8 and newer
are based on B919 and you need to flash the stock B919 as base for those newer MIUI-ROMs (everything starting from 2.6.8, as of time of writing 2.6.29)
I think B919 cannot be downloaded from huawei anymore, and the newer B923 locks the pink screen so you cannot switch to custom recovery, which you need to deploy custom ROMs.
I've repacked the B919 Stock ROM into a 7z to make it a bit smaller and put it onto my NAS:
http://kaefert.is-a-geek.org/huawei_honor/B919_official.7z
UPDATE: I just found that if you have the direct link you can still download B919 from Huawei: http://www.huaweidevice.com/cn/downloadCenter.do?method=toDownloadFile&flay=software&softid=NDE2OTU=
(found this here: Android Forum & Community - Android-Hilfe.de)
Espedine
any idea how to get out of my situation? cant seem to find the answer online, all its giving me is replace the recovery file but i cant even go into mass usb mode in pink screen... now its just stuck on image signature verify fail cant boot up. Only this and pink screen any ideas?
any help is greatly appreciated!
nannoid
-Flashing to B919-
Download B919, extract and place inside dload folder in TF card.
Remove battery from phone and reinsert.
Hold down Vol Up and Down button along with sleep/wake button.
Flashing to B919 in progress.
When done, delete dload folder from TF card.
-Custom Recovery-
Connect to computer and replace recovery.img
-Installing MIUI-
Place downloaded MIUI.zip into TF card.
Hold down Vol Up Button along with sleep/wake button (this will boot into recovery)
Flash MIUI.zip using recovery.
Done.
Espedine
-Flashing to B919-
-Custom Recovery-
-Installing MIUI-
Hold down Vol Down Button along with sleep/wake button (this will boot into recovery)
Done.
hi thanks for the quick reply!
what recovery.img file should i be using?
nannoid
Espedine
hey sorry i've installed the IMUI already but i keep getting booted into recovery mode even though i've done all the wipes any idea?
edit: is it because ive installed rom manager before?
edit: nvm just did a clean install with everything wiped, worked!
adidasfreak
-Flashing to B919-
-Custom Recovery-
-Installing MIUI-
Done.
OMG thank you so much for the simple post. Totally helped end my days of countless searching and trying to root this phone. Clear instructions and the 7z file really helped much!
Espedine
Currently using imui, superuser keep block the imui some an quan fu wu(security service) also superuser block stuff without prompting me, even though I've changed the setting to allow all
xonix
From Huawei Facebook Page:
ear Valued Huawei Users,
Latest Updated On Huawei Honor Non-Camera Certifications:
Currently only phones that are bought from Telco's are approved. You are advised to bring along your Telco's Contract/Receipt along with your phone for endorsement.
The Certificates are still pending approval from relevant authorities and we will inform as soon as greenlight is given.
The Certification is a solution as standardized documents across Huawei Honor bought from Telco's as well as non contract phones which does not come with Telco's invoice or proof of purchase.
Thank you for your support. For your convenience, there will be 2 ways ...to obtain your certifications for your Non Camera version Huawei smart phones. ( We will process your request once the certificates have been approved by authorities)
1. Huawei Hotline
How to:
Call Huawei Hotline 8006011450 and request for your certifications and you are required to provide your name, contact details and Phone IMEI no. Huawei will process your request and contact you once your certifications are ready for collections.
2. Walk-In to Huawei Service Centre @ The Cathay
How To:
Visit Huawei Service Centre together with your phone, you are required to provide your name, contact details and Phone IMEI no. in order to process your request. Huawei will process your request and contact you once your certifications are ready for collections.
Please Take Note:
You are required to produce your Huawei Non Camera Phone and Proof Of Purchase and your Identification Card during collections of the certificates for verifications and checks.
Huawei will only recognise and accept requests for certifications for our Non Camera phones that are produced solely by our factory and resumes the rights to reject any request for certifications should the phone/device be found tampered with by unaurthorised third party procedures. The Warranty will be voided should any device be found tampered with as per warranty terms and conditions.
Kaer
