fwl18
- Jan 4, 2002
never. my HMP is always fitted with a M1 data sim.
hmp is pretty heavy...heavier than note, can this take the weight?
my battery drain is average which is normal for 3G connection. that's why my set is always in power save mode (3G will be auto cut off after screen off for >30mins). on average, i only use around 1 hr++ a day and it can last me 4-5days per single charge.
as for the fast boot thing, i can't see the difference. even when it is activated, my set still takes a while to boot. anyway, i rarely fully shutdown the tablet so the slow boot doesn't bother me. mostly just screen off.
are you using wifi? may be you try to manually switch off the wifi first, before letting your set go into sleep mode. because if the wifi is running in sleep mode, then it will be consistently polling for wireless connection. this put a toll on the battery greatly.
Btw my fast boot is really solid. It boots up in like only 12s or so. I can tell it is a boot as all programs will be gone. In sleep mode the programs are still around. You should try this.
I am on ICS. 3G drains my mediapad within 1-2 hours of surfing. Is your set also facing the same problem or it is just me? I have battery savings and switched off my 3G and wifi regularly. I can hardly last 3 quarter of a day with just light surfing. Frustrated. With the unique power plug, hard to even buy a portable battery to recharge on the road.
i tried the fast boot just now. with fast boot activated, it clocked around 50 - 55 secs. the timings were around there be it cold or warm boot.
when fast boot was disabled, it boots up marginally slower @ ~60secs.
but like i say, i hardly perform full shutdown on the HMP. so i'll just leave it as it is.![]()
Hi all,
just wanna check with you all who have update to ics.
does the volume button get invert after
after i update my mediapad and holding in portrait position.
when im pressing the upper volume key, the mediapad is actually lowering down the volume.
does you all also experiencing the same issue?
i hope, too, brothers here can help source for a USB to pin type of cable for charging this tablet.![]()
to avoid any misunderstanding, i will not provide any direct link to the seller's site.Sorry I refer to the USB chargeing cable for hmd
if anyone is interested, just search for 'usb charging cable mediapad' in ebay.
the USB charging cable, came in a small package, arrived this morning from HK. the cable is about 1 metre long and works fine with my portable charger.
