I will require a sd card for upgrading? Any simpler way?![]()
can try calling up the service centre and ask if provide the update service.
yeah face the same issue as u.... after 2nd package just stuck at OK... so pull out batt...
somehow i feel it drain battery quite fast
I installed the 2 package, first was smooth, only the 2nd vendor package stuck at a big OK have to remove battery to reboot. However the stupid camera app is still there. Other than that smooth operation. Wonder if that will void the security sticker since the camera app is still there.
the camera app should be gone after installing the 2nd package. your lock screen swipe left shortcut is camera or silence phone?
Camera, I have updated the firmware twice. Just to confirm,
1. first you copy the main package to dload folder in SD card root than update.
2. 2nd delete the first main package and copy the 2nd Vendor package and apply update right?
I have done the above twice already and yet the bloody camera icon at lock unlock screen and inside phone still there, only this tiny problem other than that all is smooth.
your pull down menu got the wifi bluetooth gps shortcuts? if no that means the 2nd package wasn't successful.
The short cuts r all there when I pull down the menu so meaning the 2nd sucessful package installation is sucessful
weird. mine swipe left is silence the phone.
How do you create folder in ics?
drag the app into another one..
You cannot do that in the apps screen right? Do anyone have problem sync the facebook contacts with ur contact list?
