hi there.. mind to share how u all flash back to GB? and also where did u all get the file to flash back?
refer to post 912
Yep.
I believe the shortcuts belongs to Singapore's vendor package.
Yep.
refer to post 912
If u need to visit HW service ctr pls take note it no longer at The Cathay anymore, i have wasted my trip there, as it did not update the internet site!
The new service ctr have re located to Luckly Chinatown, after Western Union 2 shop.
#01-03
from outside u will nvn know it is a HW service ctr!
Владимир;71464213 said:any feedback for those who already used HUAWEI Honor firmware(U8860,Android 4.0,V100R001C388B930,Singapore Camera)? i m going to flash it laterthanks
After replacing recovery image to clockwork recovery, safely remove the phone and do a battery pull and restart the phone.
How I downgraded my Honor:
Staring Out of That Window: Downgrading My Huawei Honor Non Cam to Gingerbread
This one dun have the quick pull down menu to quick switch data , wifi etc?
yes, that is not included.
horrible battery life
horrible memory management
Battery slightly worse. Widgets slower.
Overall, no recommended to update.
Did u try the vendor pack from huawei ics upgrade?
Владимир;71470099 said:wah riao, like that how? what is the most pop root fw u all using, i just realized this version cannot be rooted, caused recovery cannot be installed at all. wasted by whole afternoon trying.![]()
No.
IMO don't bother with custom ROM if you want stability, the last few custom ROMs I tried didn't have its google maps working. (Xperia Style, FlyRazer 2.0.2)
That was enough to make me go back on stock.
I believe the more popular choice will be GB Cyanogenmod 7.2 RC1.
Which version are you referring to?
So far all of SG's Huawei ROMs can be rooted.
Владимир;71483714 said:i m referring to the SG ICS stock rom.
the problem is when i go to pink screen and pc doesn't detect the hp at all, thenfore i cant go into the \image folder to copy recovery.img into it, that is pretty the end of the story already.
care to share your how to get around with this.
i have tested using any android 2.3 huawei hp on the same cable and same pc, it can detect. maybe i miss something.
when this honor was in 2.3 it can be detected, but not after i flashed to ics.
please help. thanks.
Bootloader is locked, you do not need to replace the recovery.img to get the phone rooted.....
