N7105 Root and custom rom flashing tutorial (R&D stage)
  • Need someone to talk to?
eijnaix
Hi all brothers, I need some help here.
Going through the instructions many times, I am met with a hardware issue.
After selecting the .tar file to be patched, I am supposed to plug in the phone to the computer via usb in download mode. I understand that in Odin, a port has be colored yellow for it to register my device am I right?
If so, then here's the hardware problem I was talking about: It only shows the 0COM:3 in highlighted yellow WHEN I TURN ON THE PHONE TO NORMAL MODE. When I plug it in in download mode, it doesn't show anything.
My USB debugging is turned on based on other tutorials from other websites. I am still stuck.
Need serious help. I'm on LJ5.
switch off your phone and put it to download mode...
wai
Ya I rooted it then flashed that ROM lor.
Did you try opening the Multiview sidebar then go down to 'Edit'? Then u will see all the apps you have that you can drag it into the Multiview sidebar.
possible to add whatsapp to the list?
SLstweeter
Finally rooted my note ii lte after updating firmware to LJ5
Purpose of rooting was to move apps to SD and placing custom apps onto the multi window
However, apps2SD is not supported, and link2SD requires 2 primary partitions on the SD.
I do not wush to reformat inorder to repartition, so I'll hunt for other solutions, mayb directory binding...
Now, multi window, the method from xda that involves flashing a custom zip file, only shows settings for LJ1 and LJ3.. any idea if LJ5 can use the LJ3 settings?
Thnx
ducky_88
Root check
Is my rooting correct? it seems that the green bar is still at the same spots for 10mins. :(
edited fix. problem occurs because of using third party cable. :D
anbody using custom rom?
kEvinErd
Thnx
Oh you referring to the one on modacco right? I'm interested to know if it's supported on LJ5 too! Anyone tried?
SLstweeter
yeah. that one. with the link to create your own zip for flashing from modaco
so far, the only 2 apps that i wished to have on my multiview is "whatsapp" and "SB Buses"
don't think i will flash the hk LJ4 rom just for that ..
kEvinErd
Yea same.. If only whatsapp can be supported officially. I don't really want to go through the hassle of rooting and flashing cwm just for that though. Quite happy with present out of the box state. No problems whatsoever! Haha
stephan
If you read carefully, I did say that when in download mode, the com port doesn't show up in Odin.
try different usb port.
for my case, same issue like yours when I used the front usb port, but no prob when I use the usb port which directly from motherboard.
gibson7
Thnx
just try? lol
last time i also just whack.
don't forget, that was meant for 7100 in the first place.
