Huawei Honor U8860 non camera Users come in
adidasfreak
No.
IMO don't bother with custom ROM if you want stability, the last few custom ROMs I tried didn't have its google maps working. (Xperia Style, FlyRazer 2.0.2)
That was enough to make me go back on stock.
I believe the more popular choice will be GB Cyanogenmod 7.2 RC1.
Which version are you referring to?
So far all of SG's Huawei ROMs can be rooted.
Shendu ROM based on CM9 is quite awesome! Speedy and stable. Not to mention beautiful interface. I am using it now.
Doc3000 MIUI was initially good, then started lagging after a long time for some unknown reason.
Stock GB is still good, dont use ICS Singapore.
If u want stock ICS, should use Chinese B923 or something better and manually install Gapps.
If u want stock GB, I think use Germany B870 is the best.
Just sharing my two cents.
pioneer79
Hi all,
A quick update. I just bought from a handphone shop dealer. There's a cert included inside. Can I bring this phone to 42 sar? Will they give me a sticker?
as long u have the cert
yr unit Security officer must give u the sticker
just go register with him
pioneer79
The service ctr called me inform me that my repair cost $330!!!!
i no think i shl repair it right?
DigDub
what u broke?! so expensive. might as well fork out a bit more can get a new one already.
any 1 know how to unlock the bootloader?
last time i was on SG stock rom, 2.3 then play china mobile rom ics, ended up locked my bootloader, now how to unlock it, i guess couldn't possible downgrade to 2.3 already right?
Nakedtoes
where to download shendu Rom? can use on non cam honor?? btw does it has the slide down quite switch for data, 3g, wifi, gps , etc?
STiTUNED
Thanks. Which means on the day I am enlist, the first thing to do is to show him the cert in exchange for a sticker?
Please confirm if it's true as my friend said 42 sar will confiscate phone for 2 weeks BMT than return?
junyanyap
Hey, after i downgrade my ICS to GB, i tried using the vendor package on GB, but my phone keeps restarting without able to unpack the vendor package. any help?
This restarting occurs with my SD still in the phone.. After i remove the SD card, it wont restart anymore.. But then if i insert it back, the problem persist.
Any idea how to solve it?
lengbebe
i heard some units may take a few weeks to wait for the sticker~? how long did you all waited~? :s11:
kingsfall
Do you guys think there'll be a honor 2 non cam version available by the end of this year or early next year?
Nakedtoes
Pls lar honor2 is 4.5 " screen our stooping Saf will not allows it..;)
DigDub
just went to the service centre. its is NOT POSSIBLE to flash back to non camera gingerbread. wtf huawei!!! :mad:
kitboi
wa! how come so many misleading replies from them? fb say dl the gb firmware.. some say go service center to do for a fee.. and now latest is not possible to flash :s22::s22:
DigDub
their fb is referring to the camera gb version. their fb say go service centre is to 'upgrade' to ics for a fee. there is no way to downgrade back to gb from ics at the service centre.
Nakedtoes
cannot be lar just a rom file and flash back... got ppl done that just that is not the official huawei one.. HUawei really a cock company
