No.
IMO don't bother with custom ROM if you want stability, the last few custom ROMs I tried didn't have its google maps working. (Xperia Style, FlyRazer 2.0.2)
That was enough to make me go back on stock.
I believe the more popular choice will be GB Cyanogenmod 7.2 RC1.
Which version are you referring to?
So far all of SG's Huawei ROMs can be rooted.
Hi all,
A quick update. I just bought from a handphone shop dealer. There's a cert included inside. Can I bring this phone to 42 sar? Will they give me a sticker?
The service ctr called me inform me that my repair cost $330!!!!
i no think i shl repair it right?
Shendu ROM based on CM9 is quite awesome! Speedy and stable. Not to mention beautiful interface. I am using it now.
Doc3000 MIUI was initially good, then started lagging after a long time for some unknown reason.
Stock GB is still good, dont use ICS Singapore.
If u want stock ICS, should use Chinese B923 or something better and manually install Gapps.
If u want stock GB, I think use Germany B870 is the best.
Just sharing my two cents.
as long u have the cert
yr unit Security officer must give u the sticker
just go register with him
Hi all,
i heard some units may take a few weeks to wait for the sticker~? how long did you all waited~?![]()
just went to the service centre. its is NOT POSSIBLE to flash back to non camera gingerbread. wtf huawei!!!![]()
their fb is referring to the camera gb version. their fb say go service centre is to 'upgrade' to ics for a fee. there is no way to downgrade back to gb from ics at the service centre.wa! how come so many misleading replies from them? fb say dl the gb firmware.. some say go service center to do for a fee.. and now latest is not possible to flash![]()
