N7105 Root and custom rom flashing tutorial (R&D stage)
  • Need someone to talk to?
gibson7
Finally rooted my note ii lte after updating firmware to LJ5
Purpose of rooting was to move apps to SD and placing custom apps onto the multi window
However, apps2SD is not supported, and link2SD requires 2 primary partitions on the SD.
I do not wush to reformat inorder to repartition, so I'll hunt for other solutions, mayb directory binding...
Now, multi window, the method from xda that involves flashing a custom zip file, only shows settings for LJ1 and LJ3.. any idea if LJ5 can use the LJ3 settings?
Thnx
Oh you referring to the one on modacco right? I'm interested to know if it's supported on LJ5 too! Anyone tried?
good news...
i flashed the new firmware LJ5, rooted it and used the previous zip file generated for the multiwindow app (from modaco) and it's back to normal.
i didn't wipe or anything. my stuff and apps remains.
initially, after reverted to stock, then root. i activate the multiapp by pressing and holding the return key...it showed some of my 3rd party apps in the side bar. but there was no other 3rd party apps when trying to edit.
this was resolved by flashing the zip i generated from modaco website using the LJ3 option last round.
edit: oh... lol don't know what's wrong with my whatsapp.... its in the app list for the multiwindow. but just can't seem to drag it to the multiwindow scrollbar. maybe I got to regenerate a new zip file or whether due whatsapp.
kEvinErd
good news...
Thanks for sharing! Do try regenerating again and see if it does work perfectly on LJ5! Btw is Singapore the only country with LJ5 firmware?
gibson7
lol, after a couple of restart and some app updates from play store and my whatsapp is back to normal lol
SLstweeter
good news...
just try? lol
last time i also just whack.
don't forget, that was meant for 7100 in the first place.
Yo mate!
Thanks for taking the leap
ok, honestly, I do not exactly know how to flash - and also the fact that I do not know how to "flash back to stock" in case it fails
tell me if these steps are wrong:
1. make a backup of the res file and store it "somewhere"
2. create the zip at modaco with the apps I want, and copy it (the zip) to SD card
3. boot into recovery, and flash with the zip from SD card
4. reboot and test
Recovery process:
if it fails, just copy the original "res file" back to where i found it and reboot and all is fine??
are these steps correct?
my best friend Google is not free tonite, so i dont wanna disturb her (him) first .. :)
NB: btw I've successfully rooted, following the steps to the T
gibson7
yes. even if the backed up res file cannot work upon restore also no worries. coz u are just a flash away. can always flash back to stock.
damn easy. Just download the stock firmware and unzip oreveal the tar file. then use the Odin application to flash as u would when u were trying to do rooting.
SLstweeter
ok. gonna try it now.
so initial flash would be copying the file to SD, and flash without using odin ya? coz i'm on Mac, though i can dual boot to windows to do odin again and reflash stock firmware (like how i root the note2 previously)
SLstweeter
.. plus i'm using stock Rom updated to firmware J5 and rooted..
it doesnt matter if it is not "deodexed" right? coz ive been checking xda, and most of the multi-tools requires the deodexed Rom
..now waiting for phone to charge to at least 50% b4 attempting.. battery level is 3x % now..
gibson7
flashing the multi zip from modaco no need Odin. just boot to recovery mode (cwm) and choose to flash the zip file u copied to your sd card.
yup, mine not deodexed too.
SLstweeter
ok. just did it !!
got Whatsapp and SB Buses on the Multi Window ..
BUT ... there's a double facebook now .. lol!!
heh, and i tried opening both at the same time, facebook cannot be pulled to the screen twice.. but doesnt matter for now..
and i just realised i would like to have Dolphin Browser on multi as well.. might reflash again.. (flashing is addictive...)
gibson7
the double Facebook is when u already have a Facebook installed, then play store got a Facebook update. It will become this way. A reboot should fix it. but there's a bug, after a reboot the sidebar will be reset and u got to add your app there again.
SLstweeter
yeah, choon choon after the flash, there was a facebook update, so it created the double Facebook :)
but, for me, after rebooting, the custom added apps still remains in the sidebar, maybe you have "too many" apps in the sidebar, thats why it is reset upon reboot? I thought I read somewhere that there might be some issues if there are a lot of apps in the sidebar, like 2 pages or something..
anyway, my issue now is, upon reboot, the sequence of the apps in the sidebar are "randomised", ie. i arranged whatsapp on top, SG Bus 2nd, dolphin browser 3rd - but upon reboot, their position were rearranged
This randomised arrangement was also mentioned in the forums - I can live with that for now
anyway, this is a great mod. And thanks for the encouragements, this is my first step in flashing .. (2nd - if you consider rooting = 1st)
now there's only 1 more thing left to do - getting apps onto the SD card..
directory binding seems to have some issues according the xda - sometimes it shows that directory bind crashes - but the binding still remains.. and there might be issues if we need to update the apps too
swapping int and ext storage - ie. mounting the SD card and "cheating" the system to let it know that ext = int, could be a solution, except the writing speed is a tad slower for external, as compared to internal
still looking for a better solution..
kEvinErd
Thanks for confirming the modaco Webtool for multi app multitasking tray is working on LJ5! Anyone knows if it can work on LIJ too..? I'm still on LIJ and it seems LJ5 may just be problematic as well from some others here..
gibson7
nope LIJ firmware cannot.
I tried it very early on.
only LJ3 and LJ5 so far. I didn't try the Hong Kong LJ4.
boonchiz
I tried using the downloaded LJ3 MultiWindow_Unlimited from Modaco and flash in CWN recovery mode. But still I can't see anyway I can add any app in Multiview.
I'm now on rooted stock rom LJ3
Thanks for any advise
SLstweeter
hmm, I'm sure you already did this, but just to be sure, did you add your own apps to the <item> ... </item>, before you generated the zip?
ie. For Whatsapp, you need to add <item>com.whatsapp</item>
boonchiz
Many thanks to SLstweeter. Fantastic It works!!!!.
Will try again after flashing to LJ5.
