Head/earphones Recommendations Thread
TeamStereo
Suspended
- Your rig : Asus Xonar DG
- What type of music : Music & Gaming
- File format used in your source : all
- Genre of music you listen to : hard rock, jrock, instrumental, metal
- Headphone / earphone type :closed/opened headphone
- Other requirements (if any) : good sound quality with decent bass.
- Budget (in figures):$200
Is a mic compulsory since you are using for gaming too?
The Grado SR80i is a good recommendation if you are using at home only and do not need a mic. The fast and accurate bass on the SR80i makes it a great companion for rock/metal music. Of course, there must be good highs as well when you are talking about the genres above and the SR80i don't lose out on that.
Even when it comes to acoustics, the SR80i just brings it through naturally without sounding digital/artificial.
Was hoping for one more portable than M50 :) I like HD25ii but damn ex..
The complys didn't give enough bass for me, I will try the Shure. H
Thanks!
You should try out the UE4000, its small and yet gives good isolation. Detachable cable is a plus as well.
Definitely not a basshead's headphone but there is no roll off in the bass and mids stand out more as well. :o
abuddlah
- Your rig (Apple iPod, S3)
- What type of usage ( Music )
- File format used in your source (mp3 320kbps above)
- Genre of music you listen to (Rock,Pop,Indie,Acoustic,Classical)
- Headphone / earphone type (IEM )
- Other requirements (NIL)
- Budget (Below $600)
Is Senn IE 80 a good choice? Using Brainwavz B2 now, looking for an upgrade
Fatty San
this pair will suits your needs well but not sure where you can get it. was a gift from a family member from Malaysia
ShAnE LeE
the er4 by etymotic or westone 4
rickysio
I don't really like the IE80's bass. Best if you test it yourself first.
TeamStereo
Suspended
IE80 not bad at your price range =)
It has a quality finish and it feels light, forward sounding and pretty good soundstage. I personally feel that the IE80 sounds best with the middle tuning. Good separation and clarity without sibilance/boomy bass.
Westone 4 is more balanced sounding. Smooth and coherent sound and its very comfortable as well. =)
LouisLoh
The IE80 will sound very very muddy next to your B2. I'd suggest UE900 or W4.
jermx9
Looking for a gift for a friend
- Your rig: iPhone 4S
- What type of usage : Music
- File format used in your source : mp3
- Genre of music you listen to : Blues/Country
- Headphone / earphone type : IEM
- Other requirements : -
- Budget : 30-50
weng
- Budget : 30-50
At that price, i suggest ordering a ue500 from amazon. 27usd + shipping prob about sgd50 odd?
BradenHeat
- Your rig (mp3 players, amps, soundcard etc) --> HTC One XL Beats audio, MBP
- What type of usage (movies/ gaming/ music etc) --> Music and video when on MBP
- File format used in your source (i.e. flac, mp3 etc) --> mp3 mostly,
- Genre of music you listen to (classical, jazz, metal, etc) --> Broad range, mixed of all types would prefer solid bass, above normal for higher sounds
- Headphone / earphone type (closed, open, cirumaural, IEM etc) -->IEM
- Other requirements (if any) (mic, volume control, 5.1ch, 7.1ch etc) --> tougher than my old- BrainWaves
- Budget (in figures) --> SGD $90 to SGD $120 [ however, if slight above the upper range, i just need the justification over my budget mind, e.g tougher or well all-rounder-which can last ]
Thank y'all for the time, in advance.
Hopefully can get the purchase later on from Plaza Sing, yes, im looking at a certain sig as of this moment lmao:s13:
kaixax555
- Budget : 30-50
vsonic gr99 would make the perfect gift
kaixax555
hmmm
Dunu Ares I guess
TeamStereo
Suspended
- Budget : 30-50
For 30-50, you should try the Creative EP660 or if you stretch a little to around 60 you can get the Creative EP660.
Reason why I recommend the 830 is due to the improvement over the EP660, it has good mid-tones that is precise and not boosted/unnatural. It can produce booming bass at low volume too but clarity maintains unaffected.
Mic if used on HTC must see if its compatible. =) Those compatible with Android devices and have volume are those with the analog volume control.
You should try out the UE400vm since you will be using it for your phone as well. :s22:
Good clarity and it has good bass rumble too, comes with a slim case for storage of the earphones. This allows the case to be easily slipped into your jeans. =)
wauuuuuuut......
another new brand i've never heard.....taiwan....?
hmmm....im scared :s13:
but thanks for the suggestion, will take a look later
Its a china brand but very good performance. =)
The Dunu Trident is a good choice too, punchy bass and treble is well handled too, but might be a little scratchy for certain tracks.
Despite having a slight V shaped sound, the mids is still lush and textured. If there was a flaw, it would be the scratch treble but very good choice at its price! :o
BradenHeat
haha, not for mic or volume control.......if inbuilt then okay,
thanks, will be dropping by p.s later, but if you dont mind, whats the pricing for those two items??
TeamStereo
Suspended
Dunu Trident is $59, and the UE400 non mic is $99 and the UE400vm is $119. :o
kaixax555
wauuuuuuut......
china
build quality is top notch
hard as a rock, i believe it can last really long
BradenHeat
EHHHHHHH!!!!!!???????
59!?
i thought it would be through the roof exp,
and LOGITEC DOES IEM!?
gosh, i'm really need to catch up on the industry, phones, coms and software, but the fastest is earphones :s22:
alibaba136
anyone can recommend me a bluetooth headset ?
Criteria :
Portable
Stereo
below sgd100 .
Thanks !
