Samsung Galaxy S3 - It's Finally here!
gapboy
Hi all,
I just got my S3 non LTE. When i want to update the software. It prompt, phone has been modified. Software update not available? What it mean? If there any way that i can do the update?
likely due to rooting of the phone and 4.1.1 detects it
Nichi
Hi all,
you rooted yr phone b4?
terry2005
guile
so this is an upgrade from 4.1.1 to 4.1.2? Or it's an update for 4.1.2 users?
It's an upgrade from 4.1.1 to 4.1.2 with the patch. I'm not sure if it includes all the features of the Premium suite, but it definitely has the multi-window.
I didn't really explore much into it but i find it faster and smoother than before.
terry2005
then if i'm not 4.1.1 yet, then i cannot use this patch?
Laneige
how much is it to change camera?
i think motherboard 200+
lcd 100+
camera leh?
guile
dunno leh...you can try out on your phone and let us know...
it didn't wipe my phone after updating...everything is still intact and i used the method listed on the tutorial.
Montoya
An even newer firmware is out now XELLC. Don't know if Samsung is gonna push out this version instead.
Ds_Cheng
Ds_Cheng
I brought 2nd hand one. I had flash to 4.12 guile link. Now i check my status, it show samsung offical firmware, but it show customs binary download: YES( 1 download). What it mean? is it mean, it was root before lolz.. Sorry, i am totally noob in android. I just change to android.
o.o123
assuming ur phone it rooted already, run triangle away(google it) if ur binary download is 0 u no need to proceed further if not flash stock rom via mobile odin or pc odin(google it) and factory reset via recovery.
Ds_Cheng
Mine show download 1. Yes root before I suppose.
bhkpop
I thought the fix is out already and not in form of new firmware?
"The "Sudden Death" issue is caused by firmware on the (16 GB) VTU00M, revision 0xf1 eMMC (Embedded MultiMedia Card or internal memory if you like). Samsungs Kernel Source Code (Update 7) has been identified as the fix." - Taken from XDA -
Or I missed out something else and the fix is in XELLxxx instead?
Update:
Just read it that for those that motherboard is not changed in Samsung service center and updated to update 7, the update is indeed from those firmware..
Mine just got back last sunday and when I check, it is update 7 though firmware is still 4.1.1...
guile
Update:
How did you check if yours is number 7?
bhkpop
Code:
http://forum.xda-developers.com/showthread.php?t=2091045
You have to install some program then check the result.. Just follow the step in the link I provided.. =)
be3hive
noob qns.
if the screen got burn in marks. can get replacement form service center?
the bottom half (keyboard) got burn in marks.
thx
kennyboy
noob qns.
thx
The only way to know for sure is to try. No one can tell u for sure. :(
