Huawei Honor U8860 non camera Users come in
LesterQ
I am thinking to get the Huawei ascend p1 but I am worried about their warranty support.. How is huawei's warranty like? Good or bad? How long do they take to repair?
Insane11
Any bro using the Honor in camp without the msd sticker? Some say the cert is enuf, some say need sticker to bring in. If not, Ill get the iNO instead
Any bros from Jurong camp I?
zhenquan108
on miui 2.12.21 , apps force close , keyboard dont always pop up. and my memory usage is always like 80% ++ 443/512m e.g.
Pls Advise any expert !!
JDee
After having read a few posts about shendu os first here and thereafter on xda. I decided to take the plunge because I can't take the lag on the official ICS any longer. I shall describe my process here to help anybody else that is in the similar situation as me.
First, to get the (dload_B929rus.rar) and apply it using the up + down + power after copying the dload folder over to the root of your sd card.
Secondly, to downgrade to (B919_official.7z) just because I hear that its the most stable of the ICS roms.
Then, its on to up + down + power, pink screen, connect to pc to install custom recovery (u8860-recovery-6.0.1.0-touch.7z).
Now, copy shendu OS DEV version and gapps over to your sd card. Boot into custom recovery (up + power) and select to flash shendu os first and thereafter gapps.
It has been a breeze so far, with about a 4-5% battery usage per hour and a lag free experience. I have only experienced 1 freeze to date when I was attempting to uninstall an app. Otherwise, everything seems fine.
Just a note, that I experienced some weird screen/image defects during the initializing phase of whatsapp. This is probably a known problem because whatsapp flashed a warning message about installing onto a custom os when I first started the app.
Enjoy!
hermes76
Enjoy!
can't seem to d/l B919_official.7z, are u able to share your copy?
suchaloser
Okay, no difference in speed between gb and ics right? Just an software update which adds stuff?
suchaloser
My typical reply is - if you don't know what is rooting (in Android context), you probably have no use for it and don't need it.
To my knowledge, it's just playing with the system and CPU speed etc? And able to install non-market apps?
shadowandy
Yes, it is toying more with the system which is not encouraged by Google.
non-markets apps can be installed by turning off a check within the settings.
