Huawei Honor U8860 non camera Users come in
TopGun
yep, all chinese
I have installed it yesterday. I could get rid of all the chinese crap that comes with it except google calendar.
The calendar is also in chinese, I tried to uninstall it with titanium backup. But it is still there.. :s22:
I also cannot integrate/sync the English google calendar I downloaded from playstore..
Darn.
What other ROM can I try?
TopGun
Quite pleased with the Dalmatov CM10 ROM. Makes the phone far more usable day to day.
ocillator
Not bad a rom I would say.. But somewhat the display seems to cut off by a few pixels at the bottom in portrait mode, at right in landscape mode.
Another issue is that data usage is missing in the settings..
ocillator
To fixed the cropped resolution at the bottom, execute /etc/init.d/DisplaySize.sh and reboot.
Only restrict your orientations to 0 and 90 degrees. Disable 180 and 270 degrees.
Still trying to fix the data usage
kkenji
battery
Hi guys,
i just got my phone but would like to know if there are any reccomendations for spare battery ?
ive googled and search some sellers like corisen but all out of stock :(
enlisting next thursday so not much time left for me to go shopppinnnnggg
TopGun
ROM is 4.1.2.
Not sure about camera square as mine is non cam version.
fierymel
Hi some help required.
Flash to Dalmatov CM10 ROM but do not have data connection.
Anyone has any idea or is it part of the Rom problems?
zhenquan108
u might wanna try out going to settings and find access point then manually choose one then reboot ? thats what i did for my phone
OrLengJuz.
anyone having problems with screen resolution? I know about the displaysize.sh thing but funny mine was already 854 by default and not the 864 error that was supposedly to be there.
But then my screen still got cropped off, either at the bottom or on top, seems to be happening randomly too.
I think because of the issue with resolution it screwed up my control in mx player as well. I cant swipe the screen to adjust volume/brightness or seek video properly.
OrLengJuz.
and also it seems my honor isnt executing the init.d scripts as well cos I had a script in there to turn off the capacitive button backlights but the light is still on.
the init.d is supposed to be like the startup folder in windows right?
ocillator
Check if so is really on 854 height pixels from developer options > launch tools > configuration.
If its not, use android terminal or root explorer to execute DisplaySize.sh once.
If it is, make sure only 0 and 90 degrees rotation from settings.
Are you sure dalmatov has init.d support? The directory is there doesn't mean init executes all the scripts inside on boot. Try this app called Script Manager.. It allows you to execute scripts on boot up
arashi13
how's the ram management like for the Dalmatov ROM?
and is it possible to flash it back to the original ICS?
OrLengJuz.
Anyway to customize the lock screen animation (turn the TV effect off) and change transparency of the notification bar? dont like to have the black bar on top of my wall paper.
And, where to contact the dev dalmatov? like cannot find leh.
winguy
hi. any screen protector to recommend? the cheapo one i'm using makes the screen not so responsive. thanks.
OrLengJuz.
Me looking for casing also.
Btw, to those using the dolmatov ROM, anyone experiencing hot battery? I never got that issue before using dolmatov, was using docs3000 MIUI gingerbread previously.
Also, seems that the ROM has problems with camera apps other then the stock camera. I tried using instagram, 360 panoramas, photoaf, actionsnap, and all got distorted images on the viewfinder. Why??
