The China Android Phones, Best Value, Updates
buzzmario
I feel some models with 720p and the current 6589 chip are worth buying though. Might want to wait for 6589T if you want a 1080p screen, as most models still seem to lag abit with the 6589.
hi when you say 6589 chip , what is mean? i was looking at jiayu g3 and g3s, g3s stated as 6589 and g3 is not. mean g3s has a better chip than g3
buzzmario
Anyone did order at antelife? Does all set come with free screen protector and play store? I am looking at jia Yu g3s.. thanks
rECKleSSfElla
UMI X2? btw I will be getting the 2G RAM 32G ROM version :D
Only confusion right now is there are 1.2G and 1.5G CPU version :s11:
Someone in this thread bought the 1G/16G version but so far no review
from him yet.
basically the difference is MTK-T has higher clockspeed = better performance.
UMi X2 Turbo benchmarks published, our first look at MT6589T power
But to be honest, the increase in performance aint that significant and with this phone running on 1080p, every little bit helps but i still expect there to be lag issue since mtk chips aint that great on performance in the 1st place.
1_Fang
More depends on the rom.
I have a Lenovo S890 mtk6577 with Lewa Rom, used for a month before passing to my dad.
It is smooth with Lewa rom, comparable with Samsung S2 with 5" screen, and a much much better battery life.
cc2mss5
Not worth the price based on its 720p screen n 1st gen mtk6589 chip. 1080p fhd screen phones are releasing soon n alot of existing models are gonna get updated with mtk-t chips at no additional cost. Hold your horses for 1-2 mths and wait for the newer models to be released and see if the older model prices may drop if u really aiming for those.
dun really think will need 1020p though i agree its priced rather high. neo n003 to be sold at rmb1,299 just dat officially available in 25jun
supergmail
how your user experience when compared to note and note2?
simcher
guys, is the Oppo Find 5 a good phone? recommending a phone for a friend....
Enclave
the latest firmware is a disaster. Notification for gmail and whatsapp were all not working. You had to open the app and it will have notifications or go to app setting to reset all app data. (This was after reading the oppo forums)
It's almost like a work in progress for their firmware or in short when you buy their phone, it's like testing it for them. The phone comes loaded with their forum app so you can just post feedback there.
End up had to revert back to the old firmware, they even apologise for their latest firmware.
So if you really want Oppo Find 5, take note that the stock FW has bugs but the good thing is that the oppo development is constantly fixing them.
I recommend using it with Paranoid Android and it's easy to root also.
I don't recommend the find 5 if you friend is not into flashing firmware, rooting, reading forums for solution.
Invest in a portable batt also, it's a must have accessory for the Find 5 :s22:
buzzmario
any advise on this
MIZ Z2 Android 4.2 MTK6589 Quad Core 5.0 Inch HD Screen 1G 8G 5.0MP Front Camera Smart Phone
MIZ Z2 Android 4.2 MTK6589 Quad Core 5.0 Inch HD Screen 1G 8G 5.0MP Front Camera Smart Phone - Wholesale Electronics on AntElife.com
and
Goophone X7 5 inch 1080P Screen FHD MT6589 Quad-core 13MP Camera Android Phone Goophone 2S
Goophone X7 5 inch 1080P Screen FHD MT6589 Quad-core 13MP Camera Android Phone Goophone 2S - Wholesale Electronics on AntElife.com
i am more toward goophone but worry can the battery last or not.
thanks
nogard_0002
THL W8
Any one heard of the THL W8? Seems a reputable Company in China. think they will bring in the THL W8+
There is a bug with the Android OS though. Once you insert the SIM, you can not activate the Date/Time under systm setting.
rECKleSSfElla
One of the cheapest 1080p smartphone; iocean x7
Å·Ê¢X7 Éñ»*X7 Çà´º°æ ´ú¹º 100%ÕýÆ·±£Ö¤ ÊýÁ¿ÓÐÏÞ-ÌÔ±¦Íø
Only downside is the 2000mah battery. Deciding on whether to purchase this or the goophone x7 for spare.
Wait for the release of Neo 003.....gonna come with 3000mah batt and priced cheaper than iocean x7. But online retailers are just happy to mark up prices alot more since there is bigger demand for these china phones from overseas consumers.
Audiology93
I see. I've just ordered the iocean x7 and might get the neo 003 after it's release on 25th June.
buzzmario
hi, where you order? i have chat via the cso of antelife, very jia luck, ask one question, answer one and off line. but was told that the set order is not rooted and no playstore installed.
alos lke ask, if not rooting the set, possible to install playstore, i dun know how to root, just want a set with playstore for my to DL application,
Thanks/ Mario
