Brought my Newman k1 fr merimobiles. Overall a good phone. No lag. Just that memory is 4 gig n ram 1 gig. Screen is good at 720p
For those who are looking to get a china branded phone, Recommended buy for the week.
Huawei Honor 2 ,
Quad Core , 2GB Ram, IPS
Custom ROM Supports : 8.5/10
Stability : 8/10
Performance : 8.5/10
PPR (Performance Price Ratio): 7/10
Pros:
OEM Battery easily available, very nice IPS display, solid touch sensing, user replaceable battery, standard SIM size
Cons:
Single SIM slot, too much bloatware for non-international version (can be resolved by flashing ROM though), no local support, Custom processor K3V2 by Huawei (cannot load some 3D games), doesn't support MHL
You may ask question about other China phone model, I will try to answer them in the best of my knowledge.
UMI X2? btw I will be getting the 2G RAM 32G ROM version
Only confusion right now is there are 1.2G and 1.5G CPU version
Someone in this thread bought the 1G/16G version but so far no review
from him yet.
What is the useable ram?
There is a 2G RAM/32G ROM version, initially I was also looking at this K1.
But the black front white back I don't really like it that way. Will stick to the
upcoming UMI X2 2G/32G version.
Initially preorder jiayu g4 2g 32gb. But they keep delaying launch. Then change to k1 2g 32gb. But also delayed then got to go for 1g 4gb version. Mine is full black BTW.
cybertech,
Have you ordered your UMI X2? I just ordered last night (24th May) from Antelife. By the way it is 1.2G CPU. Wondering where to buy a snap-on case.
Can recommend a phone that has the HTC sense and its design best is below $200
jiayu g can be use in singapore as normal 3g? you order antelife? or any recommended site?
