- Jan 7, 2007
Soul77:
Try your DIY antenna at a less than ideal location and see if it still works?
Soul77:
Well that may the reason why a simple device like that works...Of course cannot lah. Testing must be done to locate the best location within the household.![]()
It's not the antenna, but the location of the TV.
Soul77:
Thanks for sharing bro.
But it's still your home...
So we don't know if it works or it's just because your location is excellent..
See here. I can never get the HD5 signal using the powered antenna. I tried all the location around my pc.
But the moment I plug the diy antenna, dump it on the wall, it immediately show up.
sorry newbie question. if i connect directly from the SCV cable point to my TV using an analogue RF cable, any issue receiving Mediacorp free to air channels? It's not essential to get HD...just the basic TV.
reason for asking is that i might want to cancel Starhub TV subscription since i hardly watch.
Need your fr.
Which of the following is good for analog, which is good for digital?
Best if got experienced before.
Thanks for the update. When you mentioned the starhub technician claimed:
due to signal interference from the environment
I knew he was likely to be shirking his responsibility. Under Singapore's strict control regimen, it is almost impossible to obtain equipment powerful enough to cause interference to tv reception, unless the interference comes from nearby countries. But then, if that is the case, the whole island will experience the same inteference. Alternatively, there is a very small chance of DIYer in your block doing some unauthorised alteration to his home cable network which injected the inteference into starhub's cable network.
Starhub's distribution network involves distribution/repeater amplifiers, splitters and line taps to adjust the final output in discrete steps to individual households. Because of long cable run, they also have equalisers to compensate for higher signal loss at the UHF end. So they need time to trouble shoot. Whatever it is, their problem is transparent to us.
If you can get more neighbours to lodge a joint complaint, the voice will be louder.
Cheers.
Any DVB-T2 for PC recommended? Currently using AverMedia Dual Tuner
DVB-T PCIe card and thinking of getting the DVB-T2 version.
Antenna I am using this Daiyo EU1701
and I need to change the antenna to be DVB-T2 compatible right?
Btw is Channel U on digital already?
I have the above. On my old house, I can get HD5. On my new house, I can only get SD 5,8,CNA.
My DIY antenna is better though.
wow not bad for a diy antenna
anyone wanna try this..... same principle...
Part 1
Part 2
