Xperia Z Ultra
nestorvie
Hi all,
I just got the Z Ultra yesterday(export LTE set though), but I have some questions for reading the Sony & XDA forums.
1. Has anyone's screen/back glass shatter or crack for no apparent reason so far?
2. My Update Center showed that I have the latest firmware .493(?), even though the latest fw available is .526, refreshing the Update Center does not bring up any new updates.
Therefore I resorted to using the Sony Update Service on the PC to update the firmware, which brings me to my next question. The program shows that a 740+ MB of data/firmware is to be downloaded.
However, I only have an average internet connection, and can't download the whole thing in one shot. Does the update service keep whatever progress I have downloaded for the next time I plug the phone in again?
Sorry for the wall of text, and thanks in advance for any input given:D
1. not that I've heard of
2. where are you from? latest firmware for Singapore should be 510 as of now.
3. the download will be resumed.
nestorvie
Sad, Today i when to Singtel Shop to make a 1to1 exchange due to the screen yellowish. But still the same, the staff bring out two brand new set to let me choose and exchange. but still got yellowish screen.. Sian sia... And i do compare they display set, they're sets whiter den mine. So FUNNY and WEIRD...
I think the yellowish screen is acceptable, in fact it is soothing to the eyes. Mine is just a little yellowish, have to put side by side with another set to see the difference, but in the earlier post there was a buttie that screen is too yellow already...
I think those with minor difference can wait for the sw upgrade.
The Sony guy just called me again this morning after I sent him some photos regarding my yellow-ish screen yesterday. What he said was the new firmware release should definitely fix the issue and they are still running their internal test as of now. He's trying to push for the roll out of such firmware as fast as possible.
So I guess you should save your trip to any service centre first, wait for the new firmware and see how.
y2c_whtdouwant
Thanks for your input.
I'm also from SG, but I bought an export set. But for some reason the Update Center in the phone would not reflect the latest firmware for download:s22:
I was hoping to actually update the firmware via wifi if possible:s22:
nestorvie
This is my first Sony phone so I also don't know how the Update Centre of the companion software work. Maybe it will download the update files to your PC first, then transfer it to your phone via USB and install from there.
Silvialite
I think I'll go down today to try my luck. No harm having a new phone.
Tectrica
Anyone finding the ZU wifi card seems to be lacking? Easier get weak or no signal at my usual spot whereas other phone and devices seems connected fine.
otaku7
how much can a 1 month old ultra in mint condition fetch ah?
even though the screen of ultra is really nice, big and good for games and videos.
I feel like something is missing...
I think I'm suffering from s-pen withdrawal.
duffie
Well, it's just a big phone. Little novelties like that wear off fast. ;) I think the price is falling fast, too.
otaku7
Well, it's just a big phone. Little novelties like that wear off fast. ;) I think the price is falling fast.
haha...kind of.
I know, saw the starhub trade-in for ultra.
It's $300 :eek: :s22:
I just hope to put it on the marketplace to at least cover enough for me to end up paying $0 for note 3.
anirudhks
about 500- 600 as i know
Silvialite
Did they replace yours?
They showed me a set that was not new. I suppose the service centre is doing that to every one who brings their phone in now. I have recorded the imei number. So those who wish to counter check can PM me. My screen appears to be whiter now though, but it is still dim compared to the display sets, even with both set to full brightness
duffie
That sucks, having super bright show room sets and dim sets for retail. :(
Silvialite
The set he showed me was also brighter, but it was more yellow as well. And I doubt it's a new set. The front protective sticker was not aligned with the screen.
sunseer
Can you share some benefit of rooting?
I don't need move app to SD because 11GB is more than enough for me to store the apps.
Rooting enable you t have root access which allow us to flash Custom rom (Need unlock bootloader too), Install root specify application to enhanced your phone capability etc.
Ultimately, Different user got different usage of the root.
sunseer
.532 bugs feedback from users
Original Message are in chinese
1:屏幕色温不正常
2:关闭优先的背光,重启机器速度巨慢
3:通话记录如果超过一屏,最后一个通话记录会出现遮挡现象。
4:通话记录超过两屏之后,拖动下拉条会出现返回第一条现象。
5:耗电量超过510版本
6:usb口充电532必须用1.5A的充电器充电,充电时间是475三倍,原来475时用1A充电器只需三小时。532时电脑或1A充电器不能充电,指示灯闪烁,不仅没充电,反而放电。
Use google Translate to English
1: The screen color temperature is not normal
2: Turn off the backlight of priority, restart the machine giant slow speed
3: call recording if more than one screen, and finally a call log will appear occlusion phenomenon.
4: After the call record over two screens, drag down bar will appear to return the first phenomenon.
5: Power consumption over 510 versions
6: usb charging port 532 must 1.5A charger, charging time is 475 times the original 475 is just three hours with 1A charger. 532 when the computer or 1A charger can not charge indicator blinks, not only did not charge, but discharged.
Others
1. Got 1 user sasid he got issue with 532 when he update from 526. so he force downgrade back to 475 and upgrade directly to 532. his issue resolved.
