not true.. lol.. I rejected their offer of 7000 and demanded the 7002..
so u got the 7002?
so u got the 7002?
just got the 7002. need advice on the dual band. can the router auto switch between the 2 frequencies? how to set the auto?
Yup I did....it's pretty hard for Singtel to turn me down given how I cornered them.
I'm having issues with my DSL7002GRV and my Asus N66U. I assume the configuration for the DSL7002GRV is roughly the same as the 7000. Ideally I would be able to use the N66U standalone, but for some reason I am unable to get 500mbps using that, while the Aztech can.
What I'm trying to do is use my Aztech as a bridge, while my N66U handles all the routing. Does anyone have instructions on doing this? I have tried this with poor results thus far:
1. Set Aztech Connection Type to bridging
2. Disable DHCP
3. Disable WiFi
4. Disable firewall
5. Connect Cat 6 cable from Port 1 of the Aztech to the WAN port of the Asus
With this setup, I am unable to get an internet connection if I use a normal setup (i.e. no special vlan tagging). If I use the Singtel specific VLAN tagging, I will continue to be stuck at 200mbps.
Hope someone is able to help. Singtel said they can't help since my Aztech is able to get 500mbps.
EDIT: Upgraded firmware and did 2 more factory resets. Not sure why, but my N66U is able to get 500mbps now. MioTV is not working though.
2. Disable DHCP
3. Disable WiFi
4. Disable firewall
That's one thing I don't understand why the craze on speed - for home users I mean. For gamers I understand. Unless there are tons of download the whole day - then what does one do with all those huge files? If the download is slow, one just do other things first. After all we are multi-tasking most of the time....Now if only there was something I could use all that local bandwidth on.![]()
For me 15mbps is good enough, I don't need 100mbps. But I still signed up to experience it, and have been asking myself the same question since - what to do with the speed?
7002 has USB ports. anyone know how to access?Does the 7000/7002 have USB3.0 ports and can it be used to connect USB drives?
i realised the diff when watching movie.....compared to my 50mbps days now at 200mbps watching movie is smooth sailing...i think router also plays a part
Err he's asking does it come with USB 3.0 or 2.0, not asking does it have USB port or not.7002 has USB ports. anyone know how to access?
