Proposal Ring - Part 2
spLeenfuL
Thank you for helping bro, scopes meaning looking at the hearts and arrows right
, forgot to do tt yesterday
No prob. You need to use the Hearts and Arrows scope, Ideal scope and ASET scope.
Out of the 3, ASET scope is the most important. It's the one that shows you the light performance.
Hearts & Arrows is just to check symmetry.
You can also check the GIA cert number and share here. Other bros can check the cert for you too.
tk
Gia report 2166399067
610720615561
610720615561 is not a valid GIA cert number.. 2166399067 has a HCA of 2.6, which is a bit off the recommended range so you should do a closer visual/scope comparison check before deciding.
spLeenfuL
610720615561
Missed out on your post..
Ya, the 0.40 G VVS1 proportions abit off.. depth % too high, crown angle too high also. If can, I'd avoid the round carat sizes like 0.30ct, 0.40xt, etc. Should go for 0.4Xct or 0.3Xct.
The other diamond cert doesn't exist.
WeApOn_X
JuSt got a 0.37 E VS2 for $2300 from JPI excl. setting. Any comments if this is a good price?
reitrac
I'm curious to find out too. It's been 5yrs since I last entered this forum. I was one of vivo supporters & customer in e past until I became my own diamond retailer.
jz1901, we are both in the same industry! (shaking hands)
But you must be much more experienced :s13:
How do you enjoy your work?
At first I was only shopping for myself, then got friends, and friends' friends also wanted to buy with me...
So I just started to help private clients who buy 1~5ct diamonds or fancy shape diamonds from diamond cutters in Israel.
Fancy cuts are not as common in the market, but surprisingly I have quite a few clients asking for cushion shape.
Honey Mastard
I bought this diamond with ring setting for ard 6k. Is it a good buy?
0.72 carat F vs1
Triple excellent
Hca 1.1
Fluorescence: None
bonkbonk
Hello all ,
Wanna also ask, as im getting a relatively small diamond 0.3~0.4, what kind of setting would be good to make it "look" bigger ~ ?
commonly is 4 prongs but im thinking if 3 prongs would make it better and a slim or thick ring
Grizz.P
Hello all ,
4 prongs and slim ring will make it look bigger :)
tk
Hello all ,
try 4 prongs, slim or tapered towards the diamond, with diamond raised a bit higher..
bonkbonk
Went to jp just now...
Was recommended 2 0.32c diamonds, really good cut , both cost $1850-1950 just diamond...
Have anyone tried michael trio shop before?
hellosecrets
How's this stone?
Honey Mastard
You can put the image links and we can upload for you.
https://farm6.staticflickr.com/5267/13761022614_18a07efc12_b.jpg
https://farm4.staticflickr.com/3696/13761020244_b87be099a4_b.jpg
