[Maylyn's Preview ~ Networking] ASUS RT-AC68U
darkrust
Do you get the same speeds over at:
http://speedtest.myrepublic.com.sg/ ?
Yes. I'm getting the same problem on MyRepublic speedtest server too. And this is only happening on 5ghz band and not 2.4ghz. Problem exist on both devices connecting to 5ghz so not network adapter issue.
Latest update: Problem seems to be resolved by switching to an isolated channels. However need to monitor for a period to conclude.
mr_voodoo
where do u guys buy unifi pro ap from ?
called localled distro/email and no reply
eyz
Is anyone using the AiDisk and Download Master?
How do I delete the files stored in the hard drive attached to the router?
Or do I need to attach the hard drive to my PC, in order to delete the files?
Proximus
Just purchased the RT-AC68U and speeds are all OK.
It seems that it takes quite while for it be operational from cold start. About ~ 20 secs
Is that normal? My older RT-56U is much faster.
Is this normal if I am on merlin FW?
eyz
Can anyone help?
wilflare
having issues with my AC68U on MR 1Gbps
- using latest official firmware
did a direct to ONT
- got 900/450
behind AC68U
- got 350/450
behind AC68U, after factory reset
- got 350/450 still
Ah-Pin-Kor
ASUS RT-AC68U Firmware version 3.0.0.4.376.1663
Network map new features :
1.System status can now show CPU and RAM usage.
2.Client status can show wireless clients signal strength.
3.Client icon is changeable.
4.Client name is changeable and parental control, QoS, manually assigned IP, static route, port forwarding client list can also refer to this name.
Security related :
1. Upgrade OpenSSL library from 1.0.0d to 1.0.0m
Bug fix:
1. Fixed IPv6 and some VDSL modem compatibility issues.
2. Fixed 3G/ 4G dongle compatibility issues for some Huawei dongles.
3. Fixed secondary wan setting issues in dual wan fail over mode.
4. Fixed traffic monitor display issues.
5. Daylight saving time can be manually adjusted.
Download master 3.1.0.88
1. Improved GUI response time.
2. Improved download speed.
3. A torrent downloading task may include multiple files and user can choose which files should be downloaded.
Others:
1. Add Airtime fairness option in Wireless --> Professional
File Size : 28,55 (MBytes) 2014.07.18 update
outer92
i have purchased the RT-AC68U from qoo1O Video-Pro.Com On-Line Store,
offer price $339- qoo discount $2.00 - qoo point $10.00 = $327
wilflare
ASUS RT-AC68U Firmware version 3.0.0.4.376.1665
Security related :
Bug fix:
Others:
File Size : 28,55 (MBytes) 2014.07.17 update
tried the new firmware... still same speed issues with MR 1Gbps
what is wrong w Asus :/
