peejay05
- Nov 30, 2008
Do you use the DNS on other wifi location as well? because if you do, then that's the issue.
Most DNS providers allow u to use on multiple locations however you need to update IP everytime you switch locations.
if not, your ISP might be changing your IP more frequent than usual but that's something very rare IMO.
You can try setting up the DNS on your router instead of the PS3 and see if it's better but note that the DNS will apply for all the devices in your network, not just the PS3.
thanks for reply. I'm only using the DNS on the PS3, nowhere else. I've even tried to set up a static IP address on the ps3, but not working. it's extremely frustrating to go to the ps3 Internet browser and update my IP address before netflix works.
I'll try setting the DNS on the router and see whether it works. thanks!
