maylyn
- Jul 12, 2007
What is the slated performance of the zhone's wifi?
With the newly placed AC87U in the study, the wifi doesn't even reach the toilet, which is <10m, though with 1 or 2 walls depending on how the line is drawn. Finicky!
Thinking of taking my friend's suggestions and using a mikrotik in place of the zhone, and then using 1 (or 2) unifi ap pro.
Currently how long does it take from registration to activation? My ST contract is almost up, and I'd figured that I should consider jumping ship, since ST doesn't offer ISP mail with 1Gbps.
ps: Not trying to ask if VQ has email, and I might as well use existing own domain name for email from here on whether I recon to ST or sign up VQ.
You go help me find suitable LN2 pot first + mountings onto the CPU die![]()
I sponsor my Fluke 50 Series thermometer for your usage for free
Don't even know ARM CPU can be operable @ extreme negative temperatures![]()
My server's CPU TDP is 8x95W in 2U space, the water may boil
Hi, check one-time charges over at the signup forms ViewQwest Pte Ltd for the plan u wish to sign up.
Home voice is now available for $3.95/mth if i not wrong. (for new recontract customers. if you had voice bundle free previously it remains free.)
As for porting number from MR i leave it to Nic or monkey.![]()
as a smaller RSP it isn't cost effective for us to support number porting presently. However as our subscriber base (slowly) grows this isn't set in stone of course
You will be able to opt for another yet-to-be-announced promotional bundle which some will find very attractiveis the current 600mbps package the sitex deal?
thank you.
My server's CPU TDP is 8x95W in 2U space, the water may boilI want to put 135W CPUs in still
You will have to wait for the SITEX promotional sign up forms to be made available on our website in order to enjoy the SITEX promotion by email sign-up, at our showroom or at SITEX itself.do you mean to say i can choose to change it to the sitex one w/o additional cost? i ask cause i don't want to do any sign up now and then to miss a better one when the sitex promo is out (if there is one).
thank you for the sibei prompt response.
wanna ask on behalf of someone, does viewqwest provide webhosting services for business?do you mean to say i can choose to change it to the sitex one w/o additional cost? i ask cause i don't want to do any sign up now and then to miss a better one when the sitex promo is out (if there is one).
Heat convection via water is one of the best
What is TDP 135W CPU? no kick for water cooling
Air cooling is one of the worst due to very poor heat conductivity.
Any1 had heat issues with zhone router? Mine is inside the DB closet and I feel the top surface with my hand is hot!!
Is it normal for the router to be so hot? I on it for 24/7 non-stop bcoz of my ip cams.
Ask them to fix teaming first instead of playing with their barbs and tubes
You might be disappointed? LOLCan't wait for the Sitex promo.
Any hints?
The Zhone wifi definitely will not live up the the AC87U, haha. It could be that your home has certain structural beams/features that results in the poor connectivity, in which case you have to try locating the AC87U in a different room.
Cable up with Cat 6it'd be pretty fugly to have the AC87U in master bedroom haha.
what options do i have? repurpose the ac87u as the main router, buy another AP like unifi?
leave the ac87u as it is, buy a unifi? replace the zhone with ERL/mikrotik.
just how good is this unifi? heard it's wifi range is crazy![]()
Worst hint ever. But eh for those who do not want the bundle, I can buy the <ahem> off you :3 told my boss I want a new <ahem> and he said deduct from salary <cries>
