Engine Light on
Yin2008
Hi everyone,
My engine light lights up & went to ws to diagnose... Found following error;
a) # 4 misfire
b) Error code 0172 (tink it got to do with O2 sensor)
Any ws to recommend? Is it worth to do the repair as ride left abt 9mths nia...
TIA.
tk
if u dun repair car die halfway on road then how? :vijayadmin:
jury_pack
Spark plug not firing properly in cylinder 4 plus o2 sensor failing. Dont change o2 sensor can, just your ride will drink fuel like mad.
SBS2716G
My car engine light also on n off alway. Error code gotten is p0506.
Yin2008
Hi all,
I really appreciate all ur valuable feedback...
But e funniest part is i dun feel any power lost when accl le... i tink e worst case will be covertor kaput (touch wood) which of coz will then head to scrapyard liao... hence, am lookg for realiable ws, hopefully they can do a thorough check instead of juz pinpointing to the sensor juz b/c e scanner display this error code...
Anyway, do keep sugg/advice coming in so that i had more options.
Thank you all!
scsim002
Your misfiring may cause O2 sensor reading error also. Check your plugs and your coil. Is your FC ok? If FC and idling OK + starting ok. Then just ignore it.
scsim002
Hi all,
Thank you all!
Cat converter kaput? Who cares.... It only affects your emission.....
scsim002
He say throttle body dirty. Say because I pump Malaysia petrol. Haha v
That is UTTER BS........
Throttle body dirty has nothing to do with petrol. Its due to your engine oil.
If you look at your valve cover, there is a vent tube to vent blowby gas back into your air intake. This is what is causing the problem. Oil vapour coats onto the TB and dirt from the air is trapped by the oil. So you get super dirty TB over time.
Only solution is to vent it out (not environmental friendly though). But if you do that you will find your TB nice and clean all the time.
jury_pack
Thorttle body is because of air la... That part also dont have any oil one. If you always behind lorry or Malaysia Lorry that emit black smoke, your throttle body very fast dirty. Also depends how frequently change air filter.
scsim002
The oil comes from the valve cover vent tube and its your engine oil.
Yin2008
So can it also be the other way, ie; O2 sensor causing misifiring (tink i heard e mech say) ?
So far, fc ok... so if i ignore it, e engine light will always on ah... somehw, will feel 'uneasy' ... haha...
Yin2008
So far, FC not really compromised... Sian, now everyday driving will see the engine light there... Want to brg to reliable ws which any bro/sis can recommend here... Like I said, at least check for what causing the problem b4 pinpointing to the sensor, juz b/c e scanner say so.
LameEntertainer
Got try reset the code and see whether it comes up again?
