htngwilliam
- Dec 31, 2004
Hi There
I guess the missing 5G SSID and Limited connection still not yet have solution so soon ?
Always got this limited connection thing. Haha! Pain!
Hi There
Laptop or Smart phone ????Always got this limited connection thing. Haha! Pain!
Win 8 laptop. Always get limited connectivity.
Hi JK
I have limited connected on Toshiba Ultrabook using Intel Centrino Advance N 6235 Wifi. Router firmware 3.0.0.4.378_3754-g8e7db76
And I have 5Ghz Wifi disappear issue on Dell 6230.
The devices tested no issue on 5Ghz that can add on to your list are
1) Samsung NOTE2
2) Xiaomi NOTE 4G
3) Samsung S5
Dear htngwilliam,
Which firmware are you using?
Device?
Wireless settings?
We have tested below devices no issue on 5Ghz.
Macbook air 2013 - 10.10.2 Beta - AC 5Ghz
Apple IPhone 6 Plus - 8.1.2 - AC 5Ghz
Sony Xperia Z1 - Slim Rom Build 9 - AC 5Ghz
Intel Wireless 7260 - latest driver - AC 5Ghz
ASUS PCE-AC68 - AC 5Ghz
XiaoMi Tv box - AC 5Ghz
Samsung Galaxy Note 3 - latest firmware - AC 5Ghz
Samsung Galaxy Note 2 - Tested by Trichard
Xiaomi Note 4G - Tested by Trichard
Samsung Galaxy S5 - Tested by Trichard
Best regard,
JK
Check your dhcp setting in the router.
Increase the range of IP address
HiDear trichard,
Are you using latest driver from Intel for Intel Centrino Advance N 6235 ?
Please install intel driver update utility to check for latest driver
Intel® Driver Update Utility
Best regard,
JK
My firmware is 3.0.04.376.2796. I am using Sony Vaio tap 11 but having issue.
Just have a discovery ... My Samsung color laser clp315w cannot connect to the 2.4G.
By the way I cannot find the CPU Temp in the configuration pages.... still finding... I can only see the load...
U just bought the router not long ago.. yet so many problems.. why not you try to enjoy what you have and dont focus on its bugs? Hahas. I have learnt to ignore the bugs and just continue with life..
Thanks.........................You can either install Asuswrt-Merlin - custom firmware for Asus routers - SmallNetBuilder Forums
or run these commands in telnet session:
For the Quantenna SoC: qcsapi_sockrpc get_temperature
For the Broadcom CPU: cat /proc/dmu/temperature
I have tested the Jan 2014 driver from Intel Website and no more limited WIFI ....I have been trying to pinpoint the problem but there doesn't seem to be any one issue.
Everything was working fine for 3 days. Than yesterday when I started using the laptop(6235 Intel wifi card) and Apple TV. It started losing connection again. Of course, I than thought that Apple TV was causing the issue. Restarted my routers and removed it. However, the problem with Internet disconnection became even more pronounced.
I checked system logs when I lost connection and there isn't any logs whatsoever. Thus, it doesn't seem to be connected to the vlan own address issue.
This is really frustrating.
