carlover76
- Oct 27, 2002
Mai tu liao, change da strap!!!
Wonder if they will sell white strap without the unit?
What does this update do? Don't seem to find anything different. New voices?
I have just received the Healing Shield Screen Protector which is designed to be Curved Fit and do the cutting and pasting for my SmartBand Talk.
I can say the quality of the film is quite good, no poping up on the edges and this film is definitely worth it as there are 3 big pieces so you can save it and use for other Smartphone or Smartwatches in future which has curved surface.
Must cut to size or comes as pre-cut to Smartband talk size?
Mine arrived yesterday but it was pre-cut to Smartband Talk size as well as the packaging did not have the Galaxy Note Edge label.You have to cut yourself as it come in 3 big pieces which are meant for Note Edge so you can keep the rest for future usage.
This one.Did you purchase from the same seller as mine?![]()
woah.. damn sad, just lost my smartband talk omw to work today.
The good part about that band is that it's light and fits well on my wrist. But it's also so light that you won't realized it's gone.. I was initially concerned about that clipping mechanism, but when played with the display unit seems fine. Today it got somehow unclipped from my wrist somehow during rush hour.
Thought I might share this experience so existing users might be more aware.
Lesson learnt, never trust this kind of strap again. $240 down the drain...![]()
It should be like this but not sure how to remove the front side as it had a a 'tab' green sticker...I just peel and apply after cleaning SmartBand Talk face with Ronson oil....
The seller send me another package with the pre-cut size for my Smartband Talk and he told me to treat the previous package as a gift.![]()
