Sony Smartband Talk
Baal
Not sure if anyone has mentioned this before. But you can skip the music forward to the next track by tapping 3x continuously on the screen. It takes a bit of practice. I discovered it by accident.
carlover76
World Clock Extension Update available, guess it has fix the time errors. Upgrade yours now!
carlover76
Saw this screen protector for my Smartband Talk which comes in 3 pieces at a reasonable price, I will probably order and try.
carlover76
I have just received the Healing Shield Screen Protector which is designed to be Curved Fit and do the cutting and pasting for my SmartBand Talk.
I can say the quality of the film is quite good, no poping up on the edges and this film is definitely worth it as there are 3 big pieces so you can save it and use for other Smartphone or Smartwatches in future which has curved surface.
ivtec2006
Must cut to size or comes as pre-cut to Smartband talk size?
ivtec2006
You have to cut yourself as it come in 3 big pieces which are meant for Note Edge so you can keep the rest for future usage.
Mine arrived yesterday but it was pre-cut to Smartband Talk size as well as the packaging did not have the Galaxy Note Edge label.
ivtec2006
It should be like this but not sure how to remove the front side as it had a a 'tab' green sticker...I just peel and apply after cleaning SmartBand Talk face with Ronson oil....
xerome
woah.. damn sad, just lost my smartband talk omw to work today. :(
The good part about that band is that it's light and fits well on my wrist. But it's also so light that you won't realized it's gone.. I was initially concerned about that clipping mechanism, but when played with the display unit seems fine. Today it got somehow unclipped from my wrist somehow during rush hour.
Thought I might share this experience so existing users might be more aware.
Lesson learnt, never trust this kind of strap again. $240 down the drain... :(:(:(
carlover76
That is sad and sorry to hear that. :o
Guess have to be mindful when having such strap as I have tried loosing my Smartband Talk in the middle of the night then notice it when I wake up in the morning.
carlover76
The seller send me another package with the pre-cut size for my Smartband Talk and he told me to treat the previous package as a gift. =:p
