htngwilliam
- Dec 31, 2004
Guys, any good alternatives and replacement from other brands? I am sure u don't want to try another Asus?
I thought latest firmware is out? I didn't want to update first. Scare later from bad to worst
When you all experience 5G no internet but full bar.... is it all devices at the same time or just individual devices while the rest still working.?
Will the next time you hit the problem can confirm that ?all at the same time I think. normally we will just disconnect it , and connect again to the 5ghz or just connect to the 2.4ghz and connect back to the 5ghz
+ one user here no 5G issue ....For me all my Windows PC device and Android works fine. Only my iPad2 internet keeps dropping. But weird thing is iPad2 is running 2.4ghz.
Two issues I'm facing below.
1. Teaming ports on lan 1 and 2 on one 'server' with dual intel lan PC, rdp session keeps hang /dc from wireless PC using 5ghz. Smooth when using only one lan port.
2. Dual Wan failover - Primary Wan (MR) seems normal (maybe because MR lease time is 7 days; max uptime for router is 4 days). Secondary (Starhub) intermittent no connection. Sometimes will renew sometimes wont. If lease Secondary Wan least time (4 hours) renewal fails, only rebooting the router when resume connection.
And of cos all the common flood of logs.
kernel: br0: received packet on eth1 with own address as source address
kernel: br0: received packet on vlan1 with own address as source address
Seem like older generation devices don't work well on 2.4G ? .. for me my Printer Samsung 315W refuse to even connect on 2.4G.
And cool... you on Dual Wan ......![]()
Oh !!........ for me the TX power for 2.4G I set to 10% while 5G is at 50% TX ...I couldn't say mine doesn't have 5Ghz issues. I might be actively suppressing it with a Coolermaster laptop fan cooler. I also often encounter 5Ghz DC previously.
Take a look at the Temps with and without a cooler I posted recently.
http://forums.hardwarezone.com.sg/90819642-post1024.html
Firmware might be buggy at this stage. But we couldn't rule out heat issues. (Just like PC CPU or GFX; once overheat, system will hang, blue screen, artifacts, unexpected shutdown etc.)
Someone even tear open their unit over in SNB forums only to find out damage caused by heat.
ASUS RT-AC87 Firmware - Official Releases - Page 76 - SmallNetBuilder Forums
SmallNetBuilder Forums - View Single Post - ASUS RT-AC87 Firmware - Official Releases
Oh regarding the Dual Wan setup, gotta keep my cheapest $22 Starhub cable plan so to have Hubclub discounts. Which turns out the cable subscription is only abt $5.5/mth.![]()
Also good to have a spare line just in case MR Fiber down and can be use for testing purposes.
MR 1Gbps plan is just too tempting...
It is much cooler at surface touch .... could be also the reason why I also have good 5G?
I believe heat to be one of the contributing factors but it's just my guess. Reality overheating is also electronics's enemy. So with your low TX power without sacrificing signal range, could be one reason you have much more stable 5Ghz compared to others here.
Currently I'm at 2.4Ghz 50% - 5Ghz - 75%
Current Temperatures: CPU = 42 °C - 2.4Ghz = 51 °C - 5Ghz = 65 °C which is even lower then previously running both 2.4Ghz and 5Ghz @ 100%
But one of my PC is in the bomb shelter thus I cannot reduce too much. If not I'll only get 3 bars of signal which my speed test suffers slightly.
Never checked heat before but my room is almost always airconed.
Its not enough to have an aircon room. U need a fan to blow directly through the vents at the side. After abt 5mins, you'll realise the router will be cooler to touch..
U tried? I am at challenger now. Was trying out which new router to buy that can act as a access point as well. I already made a mistake buying a wifi extender few days ago thinking it could act as an access point. Haha.
