So it's not affecting non-iOS AC devices?
Actually it does affect other devices . Like my Samsung tv has the exact same issue, but we seem to use iOS devices more or what I should say is more IOS people come on here to complain about it, it seems..
Those which DC, are they AC or N?I have updates here... now using Merlin 376.48 .
1) Normal usage non of the device will DC @ 5Ghz
2) Sleep Mode - Andriod phone S5/N2/N3/AscendMate all will DC after a while.
3) Sleep Mode - IPhone 5S stay connected for the past 14 hours.
To counter the 5Ghz drop issue, I install a apps in Android phone ( Connection Stabliszer) so that even screen off... it will ping at a interval ...and stay connected.. so far my Ascend Mate7 stay connected for 4 hours .....
N or AC ....Sleep mode will DC.Those which DC, are they AC or N?
I currently have 2 devices that can support 5 GHz. The Samsung Galaxy Tab 7.7 got no issue with any FW while the iPhone 6 Plus can only work properly with 2769.
Ok, will try your method tonight with 378.50.I don't feel like retyping all this so I am going to link it, but I found something, I thought it was a fluke but now I know because others are having the same issue with multiple 87's also, it very well may be a driver from either company or ??
Read This
but the bottom line is either we are not waiting 15+ minutes with power off or its justs inherit in the firmware (drivers form the 2 companies that make the chips for this, either one or both).
I went back to dd-wrt yesterday, only doing one reboot, NO POWER cycles at all and I am up 15 hours with absolutely no issues at all.
EDIT:
The only way to fix whatever problem you are having is to flush (restore factory defaults and WPS reset) the router and reload all your settings.
The ASUS firmware always got something which doesn't run well. On 3.0.0.4.376.2769, IPv6 is not working. On 3.0.0.4.378.3885, VPN Server doesn't start when reboot.![]()
Latest version of DD-WRT is 01-29-2015-r26081, right?I am up perfectly running for 30 hours now on dd-wrt (no iOS problems, loss of 5GHz, anything that I am running), I hope merlins works for you but it is asus firmware base. Certainly worth a try .
Best of luck
What other router have high tx power like Asus ??
Those like Dlink / Linksys /Netgear .... all power low right?
I also donno ... 300mWatt also told by someone here....I have the linksys ea9200, where to find the power rating?
Dear all,
The new firmware will be available soon.
ETA release: After CNY
Changelog: Not available at this moment
Best regard,
JK
CNY holiday at Taiwan is how long?Dear all,
Best regard,
JK
