monikernemo
- Oct 23, 2014
Powerful enough to force R9 290/X to drop price![]()
I agree that the GTX 970 is a powerful 3.5GB card.Powerful enough to force R9 290/X to drop price![]()
But as many members here have said, once your VRAM exceeds 3.5GB, it is a crap card.
So it really depends on what games you are playing for the next 2-3 years, at what resolutions and settings.
Check out Jayz 2 Cents video and his benchmark tests on various games which exceeds 3.5GB.
For now my GTX 970 is still serving me well as I barely reach 2.5GB even at 1440p with Crysis 3 at max settings. But once you reach 4k things might be different.
In short, just treat the GTX 970 as a PURELY 3.5GB card and you won't be disappointed. Especially at the pricing.
But if you are the '4GB MEANS 4GB' customer, go ahead and get AMD R9 290/290X. Or topup for GTX 980.![]()
Problem with the 970 is that once vram requirements exceeds 3.5 it throttles down to 1/8 of the advertised speed which is pretty dismal. If it was designed just as a 3.5 gb card then at most artifacts or slightly lower fps nia. This problem is so much worst when I had 970 ASUS Strix in SLI.
What's your resolution? I think its not designed for 4k.
Maybe the 390/x series with '3D'/Vertical Ram technology? Hahahaactually by right there is no card design for 4k.... even for titan z....
it will burn your rig.... hahaha....![]()
Tried both 1080 and 1440 above 3.5gb.
GTX 980 SLI can pretty much power 4K to its max resolution alr.
With DP 1.3 around the corner, u can bet 4K display will becoming mainstream in very soon.
3.5 or not, I still dislike how NV want to cover it up with 4Gb. Now i abit skeptical on the upcoming GM200 if they will resort to such tricks again to the non-titan GM200.
Can enlighten on how displayport update can power up 4k when our GPU cannot even handle 4k? I think 4k in common context is UHD instead of strictly 4k. Hahaha
Huh what game? Final tidus say crysis ultra only 2.5 GB at 1440P.
It will still be quite a long way before 4K becomes mainstream...... 2 x GTX980 is not exactly mainstream.
Well like I said 16nm GPUs...
If next year 16nm card are out, GTX 980 at that point will easily be considered as mid-tier GPU.
