kimsim
Suspended
- Nov 1, 2008
I saw the servicing people using water to do my Air Con cleaning during that time.
They clean for pvc outlet pipe lah, seriously if they do with copper pipes.
They flushed the interior and using a build in net to collect the water when it's blow out. The servicing was done by IFC that time.
But GC told me for their servicing, they will remove the whole unit and clean it.
Once remove out whole thing is good, but who can guaranty gas leak after that?
Like my sharing for apply extra filter, even over a year still can avoid they serving.
If the water dripping then just going for serving.
How to apply extra filter ?
Just place on the pre-filter from the top part follow by going downward
This one need servicing people to do it, think too difficult for me to do so.
Huh just do by self loh.
Can be remove out pre-filter and just place on top and settle
This one I has using an over 8 yrs already, since I found in Daiso.
But my FCU never let for Aircon man serving a once.
Internal cooling look so new & no dust at all
bro, what is this pre filter you talking about? mind share some photos?? I can go buy..cos looking at your heat exchange still look damn new.. I like!!!!
actually I am more concern about the blower, cos it get dirty very easy and very difficult to clean, unless I know how to remove it out completely
For ME Sys 2, is it better to install compressor unit MXY2E20VA or MXY3A28VA for MSYGE1OVA x 2 units? What is the pro & con? Save more on electric bills?
The MXY2E20VA is more than enough for 2 10K BTU spilt unit.
No point wasting more electric bill on bigger BTU compressor unless you need it.
Fyi, I am using MXY2E20VA on my MSYGE1OVA and MSYGE13VA.
You can refer the all table
But honest on 3A28VA more save energy than 2E20VA
For example here :
20va : 10 + 10 = 1.44kw
28va : 10 + 10 = 1.18kw
The different between 260w![]()
But that's only if you on 2 units ?
Ya correct.
Cause bigger capacity = kw or btu can be using power input lesser
Just the specs data only, in real life we dunno. :lol:
I very confuse leh, SA told me if don't intend to fill the 3rd fan coil in living room, no point getting a much bigger compressor, higher electricity bills. I dunno, that's y I asked...
The instruction is shown on packing.
