Can anyone advise on my earlier QN? Anyone encounter similar issue?
Sent from Motorola NEXUS 6 using GAGT
I just tried..... plug in a HDD to USB3 .... RAM never up much leh ........
RMA is still brand new set. I saw my unit was opened from a brand new box..
hi can check with you guys who using ac87u. when i plug my external hard drive, how come my ram usage hit to 80-90% range where when i unplug it goes back to 20-30%?
is sth wrong here or something wrong with the firmware? im on the latest firmware. 4608
ohh okay thanks for your reply. how bout your usb 2?
When first plugged in, the RAM will shot up very high, after the indexing is done, it will drop below 35%
but mine has been running for quite a while alr. more than a day. and still te ram is still high. unless its indexing forever cuz i always have new files writting on it?
Hi all,
I am 25 hours in and I think I finally have a perfect firmware form RMerlin finally!!
see my posts here and a link to his firmware for me.
and I have beamforming off but that 0 thing mentioned here seems to have no affect so I left it at its default 3600 or something.
click here
Thanks Sir .......... I updated it ..Hi all,
click here
Please provide change log as well. TIA...Dear all,
I will be releasing 2nd stage of unofficial firmware for RT-AC87U soon.
Stay tuned.
Best regard,
JK
In AP mode --- does the traffic ananlyser work ?.......Hi all,
click here
1) If can hold the purchase, hold it first.I'm pondering whether should I get this router at such a high price with all the problems faced by this router.
Any advice?
4) Buy from IT Garage Sales.1) If can hold the purchase, hold it first.
2) If cannot hold the purchase, perhaps look at other model till Asus fix the issues.
3) If cannot hold the purchase and die die want an Asus router, buy and use RMerlin's firmware located here.
Does the RMerlin firmware fixed most of the stability issues?
Click my link on the previous page
But to me that Merlins firmware is a masterpiece
All problems are gone, I will certainly post if anything shows but I really believe that firmware is perfect (at least for everything I use).
Now I can recommend this router.
I just hope future firmware does not destroy it but we can flash back to this. Alfa3.
