What The Flex can the LG G Flex2 do?
Nakedtoes
there was a video shared earlier, not too long bah, to simulate a drop in water and quickly remove it from water. It is still working after that.
but the water sensor activate means warranty over
Nakedtoes
I have Flex1 and 2, Flex 1 is quite a durable phone as I have drop at least 5 times seriously and LG Flex 1 still function well. Havent try my Flex2 durability yet.But looking at the video, it should be quite ok. However i noticed for Flex2 the phone get heated up if i continue using for hours. Not sure if it is the internal battery. My friend say is it ok de. Overall the selfie part was good experience as you can just open and close your fist on the screen, it will start 3 secs timer. This is very good when using selfie stick. Also i noticed the battery charge faster then Flex1. Last but not last i noticed after I bought all the curve phones i have no interest in straight phone anymore. Lol..
thanks for sharing... can share whats advantages of curved phone....... why no interest in straight phone?:s11:.
Nakedtoes
AndroidCentral G4 review: http://www.androidcentral.com/lg-g4-review
"On paper, then, the LG G4 is less powerful than its concave cousin, the G Flex 2, which uses a Snapdragon 810. However this only really holds true if you sit around running benchmarks all day. In the real world, where things like scrolling speed, touch response and app load times matter, the G4 is the faster phone by a country mile. A lot of that has to do with the software, which has also been tuned up. (And in fact Qualcomm and LG are both quick to tell you that the 808 and G4 were quite literally made for one another.) But it's also apparent that the G4 isn't throttling back its CPU anywhere near as much as the G Flex 2, nor is it getting as hot during heavier use."
:s13:
Throttling is the issue .. speed at so low phone will lag then user experience not good:(:(
dawnmorra
Once again, thanks LG and HWZ for the printer! :o
Btw, I went to test a G Flex 2 from telco shop... On physical aspects, the feel is alright, bright screen and clear - no major complaints. My concern is a curvy phone might not fit into the jeans' pocket nicely and will be bulging. For the ladies, they won't have any issues since they have a handbag.
For the softwares, launching apps like camera and other basic apps lag for a few seconds. It is pretty noticeable imo, so the UI really needs improvement to push for a faster response, because the S6 isn't as bad though it lags a little bit too. I saw a lot of unnecessary apps and reminds me of samsung's old touchwiz. I wish LG will have less of those, tbh. Got 3gb ram also no need to use waste the memory like that ma :s22:
wow with 3gb ram i no need to wait for apps lag.
dawnmorra
The LG G Flex2 does not fit the front pocket well.
But will fit the back pocket better.
That's why it can stand 25KG to 50KG of weight...:s13:
Just make sure the phone does not drop out without your knowledge.
so if LG G Flex 2 drop out without your knowledge , how.
dawnmorra
LG G Flex 2 and all the curve phones interest me too.
dawnmorra
:s13:
I love LG G Flex 2 because its curve.
dawnmorra
The LG Gflex2 hotcurves is available in Platinum Silver and Flamenco Red
From the website:
With no side buttons interrupting its design, the curved form factor of the G Flex2 is both easy to hold and intuitive to operate.
The uniquely curved 5.5 Full HD Display delivers more immersive and lifelike viewing experience. The curved display phone creates optimal viewing angles to minimize glare and reflections.
Always look your best with instant Self Healing Technology that naturally fixes scratches and blemishes to help your G Flex2 maintain its timeless look.
Capture photographer quality shots with LG’s superior OIS+ that steadies every shot for sharp focused images. And with Touch & Shoot you can touch anywhere on the screen to capture stunning images in an instant.
GESTURE SHOT & GESTURE VIEW
- No more stretching out your arm and struggling to press the shutter button. Take a better selfie without pushing any buttons by making a simple hand gesture.
- Instantly see your latest selfie creation as the Gesture View feature opens your photo gallery as soon as you lower your G Flex2 camera from position
Find the power you demand to multitask at blazing speeds with the Qualcomm Snapdragon 810 processor with (integrated) 64-bit Octa-Core CPU and today’s latest Android OS.
Spend less time charging and more time doing what you love with accelerated charging that refuels 50% of the battery in about 30 minutes.
Conserve battery power and time with Glance View. Check the time and other notifications while the screen is off simply by dragging down on any part of the screen.
Check out the smartphone options offer a wide range of features, such as 3D technology, Wi-Fi Hotspot, IPS displays and more
when will Qualcomm processor come with 128-bit Core CPU.
