sohcheekeong
1 sentence for you :)
Go to support site and download latest firmware and install.
I updated to the latest firmware 3.0.0.4378 last night but Aidisk is still not working. It still gives me the same error message "Illegel IP Address!", even when I entered test.asuscomm.com (which is the example given in the user manual).
Does this Aidisk work at all? Or should I sit and wait for a future firmware before trying it again?
sohcheekeong
Should not be that problem. This is the first time I use AiDisk. Both the router and the hard disk are brand new.
Don't know what happened. It just wouldn't get through the create domain name stage.
ASUS@SG
Suspended
Dear sohcheekeong,
3.0.0.4378 << very old firmware. Did you update to the latest firmware??
RT-AC87U_3.0.0.4_378_5556-Unofficial Beta Firmware
Important Notice:
Require hard reset.
Do not restore configure settings due to driver update.
Download: http://goo.gl/ZQByAz
Remember do a hard reset of your router.
After update the router, press and hold reset button until power led light keep blinking then release.
Best regard,
JK
sohcheekeong
Dear sohcheekeong,
Important Notice:
Require hard reset.
Best regard,
JK
I downloaded from Asus website last night, version is 3.0.0.4.378_5134. Is that not new?
Anyway I will download from the link you provided and try again tomorrow.
Thanks for the help.
sentinelvdx
No issue with ASUS DDNS.
May 14 08:28:22 rc_service: httpd 464:notify_rc restart_ddns
May 14 08:28:22 ddns update: ez-ipupdate: starting...
May 14 08:28:22 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
May 14 08:28:22 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Thu, 14 May 2015 00:28:22 GMT^M Server: Apache/2.4.9 (Unix) PHP/5.5.14 OpenSSL/1.0.1h^M X-Powered-By: PHP/5.5.14^M Content-Length: 0^M Connection: close^M Content-Type: text/html^M ^M
May 14 08:28:22 ddns update: retval= 0, ddns_return_code (,200)
May 14 08:28:22 ddns update: asusddns_update: 0
May 14 08:28:23 ddns: ddns update ok
I'm getting this:
May 14 11:18:41 rc_service: httpd 447:notify_rc restart_ddns
May 14 11:18:42 ddns update: ez-ipupdate: starting...
May 14 11:19:27 ddns update: error connecting to nwsrv-ns1.asus.com:80
May 14 11:19:27 ddns update: asusddns_update: 1
I also tried to ping nwsrv-ns1.asus.com:80 and I'm unable to ping it. (Never had this problem before)
ASUS@SG
Suspended
I'm getting this:
Dear sentinelvdx,
Which ISP are you using?
Singtel? M1? Starhub?
Best regard,
JK
sentinelvdx
Dear sentinelvdx,
Best regard,
JK
Hi,
I'm not from Singapore, I'm from Argentina, I'm using "Fibertel" .com.ar.
I had no trouble with the ASUS DDNS for years, and previous versions are able to register my device (rolled back and works on 5134), so I'm thinking maybe the address changed and for some reason my area is unable to reach it.
Is ther any area restriction applied to servers used on this version for ASUS DDNS?
UPDATE: It was my ISP's fault after doing a tracert it was stopping there. contacted them and solved it. Thanks!
ASUS@SG
Suspended
Hi,
Dear Sentinelvdx,
Welcome to Singapore :)
Best regard,
JK
ASUS@SG
Suspended
Dear all,
Another new build for RT-AC87U
RT-AC87U_3.0.0.4_378_5587- Unofficial beta firmware
Fix dualwan works abnormal issue
Fix usb modem issues
Fix Territory code command
Fix Disk related UI
Fix secondary wan not work issue
Fix [Quick Internet Setup] IPconflict environment, QIS change LAN IP
Download: http://goo.gl/VshlxI
Important Notice:
No required hard reset, if you update from build 5556 firmware.
Do not restore configure settings due to the driver update.
Please feedback to me
Best regard,
JK
thiamhui
Dear all,
Fix Disk related UI
Important Notice:
Best regard,
JK
Keep it cumming!!! :D With the "No required hard reset"...
Is Beamforming going to be disabled for good? Last check on 5556 was still not good...
Jurong640
Dear all,
Fix Disk related UI
Important Notice:
Best regard,
JK
So if i upgrade from 5136 to 5587 still require reset right?
I've pmed you my device and router details, did u receive?
ASUS@SG
Suspended
Dear Jurong640,
Any firmware below 5556 then you are require hard reset.
Do not restore configure setting.
I have received
Best regard,
JK
hugosantos
DNLA Server
After the upgrade for the 5134, my dlna server is not recognizing the entire contents of the hard drive connected to the router's USB, all content is ok from ftp, only a small amount of the content is displayed in dnla.
Tested with 5587 beta without sucess.
After downgrade for 4950 works fine again.
ASUS@SG
Suspended
Dear Hugosantos,
Did you done hardreset after install 5587?
Best regard,
JK
hugosantos
Dear Hugosantos,
Best regard,
JK
Yes, several hardresets but does not recognize all content from the hard disk. Content is recognized immediately after returning to the 4950 version.
May 15 07:32:08 rc_service: ntp 778:notify_rc restart_upnp
May 15 07:32:08 miniupnpd[691]: received signal 15, good-bye
May 15 07:32:09 miniupnpd[806]: HTTP listening on port 45932
May 15 07:32:09 miniupnpd[806]: Listening for NAT-PMP traffic on port 5351
May 15 07:32:09 rc_service: ntp 778:notify_rc restart_diskmon
May 15 07:32:09 disk_monitor: Finish
May 15 07:32:11 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
May 15 07:32:11 disk monitor: be idle
May 15 07:32:12 kernel: sizeof forward param = 160
May 15 07:32:12 admin: sh /opt/S50asuslighttpd.1 start
May 15 07:32:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
May 15 07:32:18 admin: sh /opt/S50downloadmaster.1 start
May 15 07:32:18 admin: sh /opt/S50asuslighttpd.1 firewall-start
May 15 07:32:19 admin: sh /opt/S50downloadmaster.1 firewall-start
May 15 07:32:20 dhcp client: bound 186.236.214.154 via 186.236.208.1 during 43200 seconds.
May 15 07:32:25 transmission-daemon[2437]: Couldn't bind port 51413 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:371)
May 15 07:32:25 transmission-daemon[2437]: UDP Failed to set receive buffer: requested 4194304, got 245760 (tr-udp.c:78)
May 15 07:32:25 transmission-daemon[2437]: UDP Failed to set send buffer: requested 1048576, got 245760 (tr-udp.c:89)
May 15 07:32:34 rc_service: hotplug 699:notify_rc restart_nasapps
May 15 07:32:34 iTunes: daemon is stoped
May 15 07:32:34 FTP Server: daemon is stoped
May 15 07:32:35 Samba Server: smb daemon is stoped
May 15 07:32:35 kernel: gro disabled
May 15 07:32:35 Timemachine: daemon is stoped
May 15 07:32:37 kernel: gro enabled with interval 2
May 15 07:32:37 crond[462]: time disparity of 193532 minutes detected
May 15 07:32:39 qtn: bootcfg.tgz exists
May 15 07:32:39 Samba Server: daemon is started
May 15 07:32:52 dfs: start dfs scan
May 15 07:32:52 nodfs_scan: complete
May 15 07:40:51 kernel: htb: htb qdisc 12: is non-work-conserving?
May 15 07:52:39 kernel: htb: htb qdisc 13: is non-work-conserving?
May 15 07:59:57 ntp: start NTP update
May 15 08:00:11 disk_monitor: Got SIGALRM...
May 15 08:08:35 kernel: htb: htb qdisc 10: is non-work-conserving?
May 15 08:31:33 watchdog: restart httpd
May 15 08:31:33 rc_service: watchdog 466:notify_rc start_httpd
May 15 08:31:33 RT-AC87R: start httpd
May 15 08:59:59 ntp: start NTP update
leonaheidern
Dear Thiamhui,
It's trend not to save password :) Just like 007 james bond, he don't save any password too.
Best regard,
JK
I am kind of wishing I assigned an easier to type login password for my tablets and phones then. On screen keyboard ,damn cham.
Jurong640
Just updated to 5587 with hard reset. The login page interface looks nice.
Hopefully the normal page could be revamped soon
leonaheidern
I had problems flashing to 5587 after i flashed it then pressed the reset button.
Took a while to get it to recovery mode and re-flashing it with the Rescue.exe tool provided on the cd that came with the rt-87u
happy to report after tweaking the control channel to channel 1 for the 2.4ghz band and 149 for the 5ghz, the wifi now reaches my room and my maid's room like the rt-n66u used to do.
yesterday when I turned off the rt-n66u my maid's iphone 4 could not even connect to the ac-87u when the router was on version 3.0.0.4_378_5134. I came home in the evening to flash version 3.0.0.4_378_5587.
ASUS@SG wrote:
Dear all,
Fix Disk related UI
Important Notice:
Best regard,
JK
