thiamhui
hi thiamhui, can check with you, you are using singtel fibre plan rite? whats the current speed that you subscribed for? and may i ask, what is your current router firmware?
Yap, Singtel 200 Mbps. Currently using firmware version 5587…
voltech
does that vlan10 error still appear? ohh you are using the 200, i thought you maybe one of user who got upgraded to 500 from 300, it seems to me that i am unable to hit near 500mbps on our router... though running on wireless i know, not full speed but should be in the 400++ range im only getting at ~300. im not sure if my current firmware has some speed restriction.:s11: im still on the previous firmware...
thiamhui
Oh… To reach that speed, you will need minimumly a 2T2R device capable of connecting at 867 Mbps.
carlover76
I am getting around 160+Mbps on my AC-87 Wifi under 5G, is this speed normal?
Any other settings to change before I can get higher speed?
Appreciate your advice. Thanks.
thiamhui
may i ask what is 2T2R? my connection speed now is showing 877Mbps via my task manager. and asus wireless utility.
If you can see 867 Mbps, then it's a 2T2R device. Anyway, best method to check connection speed is by using LAN connection.
Depends on what's your plan and device you are using. That's the speed I'm getting on my iPhone with Singtel 200 Mbps plan...
carlover76
I on M1 1GB and using my Xperia Z3 which is AC compliant, I should be expecting higher speed?
So do I need to turn on the Firewall, AI or QOS protection?
voltech
okay but the speed still does not reflect, i did cable method and i do achieve the speed, so my wireless speed is probably restricted by the firmware? that don sound anything logical :s11:
jonim
Errors have been detected on your hard drive.
Hi Guys,
I got a new 5TB USB disk hooked up and got the following error:
Errors have been detected on your hard drive. Remove any damaged files or use a PC to correct system issues.
Does anyone have encountered the similar situation? I read somewhere they mentioned it is due to memory, is it true? I have tried tools to check disk but no negative result. But when I do a health check from Asus, I got these:
ntfsck 3014.5.21
Checking NTFS Superblock ...
Device name : /dev/sda1
NTFS volume version: 3.1
Cluster size : 4096 bytes
Current volume size: 5000972685312 bytes (5000973 MB)
Current device size: 5000972685312 bytes (5000973 MB)
Checking for bad sectors ...
Scanning $MFT ...
Checking directory structure ...
Checking for orphaned files ...
0.00 percent completed
0.24 percent completed
0.49 percent completed
0.73 percent completed
0.97 percent completed
1.21 percent completed
1.46 percent completed
1.70 percent completed
1.94 percent completed
2.18 percent completed
2.43 percent completed
2.67 percent completed
2.91 percent completed
3.15 percent completed
3.40 percent completed
3.64 percent completed
3.88 percent completed
4.12 percent completed
4.37 percent completed
4.61 percent completed
4.85 percent completed
5.10 percent completed
5.34 percent completed
5.58 percent completed
5.82 percent completed
6.07 percent completed
6.31 percent completed
6.55 percent completed
6.79 percent completed
7.04 percent completed
7.28 percent completed
7.52 percent completed
7.76 percent completed
8.01 percent completed
8.25 percent completed
8.49 percent completed
8.73 percent completed
8.98 percent completed
9.22 percent completed
9.46 percent completed
9.71 percent completed
9.95 percent completed
10.19 percent completed
10.43 percent completed
10.68 percent completed
10.92 percent completed
11.16 percent completed
11.40 percent completed
11.65 percent completed
11.89 percent completed
12.13 percent completed
12.37 percent completed
12.62 percent completed
12.86 percent completed
13.10 percent completed
13.34 percent completed
13.59 percent completed
13.83 percent completed
14.07 percent completed
14.32 percent completed
14.56 percent completed
14.80 percent completed
15.04 percent completed
15.29 percent completed
15.53 percent completed
15.77 percent completed
16.01 percent completed
16.26 percent completed
16.50 percent completed
16.74 percent completed
16.98 percent completed
17.23 percent completed
17.47 percent completed
17.71 percent completed
17.95 percent completed
18.20 percent completed
18.44 percent completed
18.68 percent completed
18.93 percent completed
19.17 percent completed
19.41 percent completed
19.65 percent completed
19.90 percent completed
20.14 percent completed
20.38 percent completed
20.62 percent completed
20.87 percent completed
21.11 percent completed
21.35 percent completed
21.59 percent completed
21.84 percent completed
22.08 percent completed
22.32 percent completed
22.56 percent completed
22.81 percent completed
23.05 percent completed
23.29 percent completed
23.54 percent completed
23.78 percent completed
24.02 percent completed
24.26 percent completed
24.51 percent completed
24.75 percent completed
24.99 percent completed
25.23 percent completed
25.48 percent completed
25.72 percent completed
25.96 percent completed
26.20 percent completed
26.45 percent completed
26.69 percent completed
26.93 percent completed
27.17 percent completed
27.42 percent completed
27.66 percent completed
27.90 percent completed
28.15 percent completed
28.39 percent completed
28.63 percent completed
28.87 percent completed
29.12 percent completed
29.36 percent completed
29.60 percent completed
29.84 percent completed
30.09 percent completed
30.33 percent completed
30.57 percent completed
30.81 percent completed
31.06 percent completed
31.30 percent completed
31.54 percent completed
31.78 percent completed
32.03 percent completed
32.27 percent completed
32.51 percent completed
32.76 percent completed
33.00 percent completed
33.24 percent completed
33.48 percent completed
33.73 percent completed
33.97 percent completed
34.21 percent completed
34.45 percent completed
34.70 percent completed
34.94 percent completed
35.18 percent completed
35.42 percent completed
35.67 percent completed
35.91 percent completed
36.15 percent completed
36.39 percent completed
36.64 percent completed
36.88 percent completed
37.12 percent completed
37.37 percent completed
37.61 percent completed
37.85 percent completed
38.09 percent completed
38.34 percent completed
38.58 percent completed
38.82 percent completed
39.06 percent completed
39.31 percent completed
39.55 percent completed
39.79 percent completed
40.03 percent completed
40.28 percent completed
40.52 percent completed
40.76 percent completed
41.00 percent completed
41.25 percent completed
41.49 percent completed
41.73 percent completed
41.98 percent completed
42.22 percent completed
42.46 percent completed
42.70 percent completed
42.95 percent completed
43.19 percent completed
43.43 percent completed
43.67 percent completed
43.92 percent completed
44.16 percent completed
44.40 percent completed
44.64 percent completed
44.89 percent completed
45.13 percent completed
45.37 percent completed
45.61 percent completed
45.86 percent completed
46.10 percent completed
46.34 percent completed
46.58 percent completed
46.83 percent completed
47.07 percent completed
47.31 percent completed
47.56 percent completed
47.80 percent completed
48.04 percent completed
48.28 percent completed
48.53 percent completed
48.77 percent completed
49.01 percent completed
49.25 percent completed
49.50 percent completed
49.74 percent completed
49.98 percent completed
50.22 percent completed
50.47 percent completed
50.71 percent completed
50.95 percent completed
51.19 percent completed
51.44 percent completed
51.68 percent completed
51.92 percent completed
52.17 percent completed
52.41 percent completed
52.65 percent completed
52.89 percent completed
53.14 percent completed
53.38 percent completed
53.62 percent completed
53.86 percent completed
54.11 percent completed
54.35 percent completed
54.59 percent completed
54.83 percent completed
55.08 percent completed
55.32 percent completed
55.56 percent completed
55.80 percent completed
56.05 percent completed
56.29 percent completed
56.53 percent completed
56.78 percent completed
57.02 percent completed
57.26 percent completed
57.50 percent completed
57.75 percent completed
57.99 percent completed
58.23 percent completed
58.47 percent completed
58.72 percent completed
58.96 percent completed
59.20 percent completed
59.44 percent completed
59.69 percent completed
59.93 percent completed
60.17 percent completed
60.41 percent completed
60.66 percent completed
60.90 percent completed
61.14 percent completed
61.39 percent completed
61.63 percent completed
61.87 percent completed
62.11 percent completed
62.36 percent completed
62.60 percent completed
62.84 percent completed
63.08 percent completed
63.33 percent completed
63.57 percent completed
63.81 percent completed
64.05 percent completed
64.30 percent completed
64.54 percent completed
64.78 percent completed
65.02 percent completed
65.27 percent completed
65.51 percent completed
65.75 percent completed
66.00 percent completed
66.24 percent completed
66.48 percent completed
66.72 percent completed
66.97 percent completed
67.21 percent completed
67.45 percent completed
67.69 percent completed
67.94 percent completed
68.18 percent completed
68.42 percent completed
68.66 percent completed
68.91 percent completed
69.15 percent completed
69.39 percent completed
69.63 percent completed
69.88 percent completed
70.12 percent completed
70.36 percent completed
70.61 percent completed
70.85 percent completed
71.09 percent completed
71.33 percent completed
71.58 percent completed
71.82 percent completed
72.06 percent completed
72.30 percent completed
72.55 percent completed
72.79 percent completed
73.03 percent completed
73.27 percent completed
73.52 percent completed
73.76 percent completed
74.00 percent completed
74.24 percent completed
74.49 percent completed
74.73 percent completed
74.97 percent completed
75.22 percent completed
75.46 percent completed
75.70 percent completed
75.94 percent completed
76.19 percent completed
76.43 percent completed
76.67 percent completed
76.91 percent completed
77.16 percent completed
77.40 percent completed
77.64 percent completed
77.88 percent completed
78.13 percent completed
78.37 percent completed
78.61 percent completed
78.85 percent completed
79.10 percent completed
79.34 percent completed
79.58 percent completed
79.83 percent completed
80.07 percent completed
80.31 percent completed
80.55 percent completed
80.80 percent completed
81.04 percent completed
81.28 percent completed
81.52 percent completed
81.77 percent completed
82.01 percent completed
82.25 percent completed
82.49 percent completed
82.74 percent completed
82.98 percent completed
83.22 percent completed
83.46 percent completed
83.71 percent completed
83.95 percent completed
84.19 percent completed
84.44 percent completed
84.68 percent completed
84.92 percent completed
85.16 percent completed
85.41 percent completed
85.65 percent completed
85.89 percent completed
86.13 percent completed
86.38 percent completed
86.62 percent completed
86.86 percent completed
87.10 percent completed
87.35 percent completed
87.59 percent completed
87.83 percent completed
88.07 percent completed
88.32 percent completed
88.56 percent completed
88.80 percent completed
89.05 percent completed
89.29 percent completed
89.53 percent completed
89.77 percent completed
90.02 percent completed
90.26 percent completed
90.50 percent completed
90.74 percent completed
90.99 percent completed
91.23 percent completed
91.47 percent completed
91.71 percent completed
91.96 percent completed
92.20 percent completed
92.44 percent completed
92.68 percent completed
92.93 percent completed
93.17 percent completed
93.41 percent completed
93.66 percent completed
93.90 percent completed
94.14 percent completed
94.38 percent completed
94.63 percent completed
94.87 percent completed
95.11 percent completed
95.35 percent completed
95.60 percent completed
95.84 percent completed
96.08 percent completed
96.32 percent completed
96.57 percent completed
96.81 percent completed
97.05 percent completed
97.29 percent completed
97.54 percent completed
97.78 percent completed
98.02 percent completed
98.27 percent completed
98.51 percent completed
98.75 percent completed
98.99 percent completed
99.24 percent completed
99.48 percent completed
99.72 percent completed
99.96 percent completed
100.00 percent completed
Scanning orphaned files completed.
Checking attributes ...
Failed to calloc 152617575 bytes: Cannot allocate memory
Checking cluster allocation ...
ERROR(12): Failed to setup allocation bitmap: Cannot allocate memory
Syncing device ...
Firmware bug?
Please assist.
thiamhui
For Firewall and AiProtection, you can turn them on. As for QoS, I currently keep it off.
carlover76
My previous N66U with firewall turn on, the wifi speed is slow, it is only fast when i turn off the firewall in N66U so not sure it is the same as AC87?
Repsol_2
Any idea how i get rid of this? I just got the router todeh and incremental update of firmware.
Current firmware 3.0.0.4.378_4608, the last two firmware i saw require Hard reset, i cannot do coz I lazy now. before that, will it fix the Deadloop?
ASUS RT-AC87U Firmware version 3.0.0.4.378.5134
ASUS RT-AC87U Firmware version 3.0.0.4.378.4950
May 18 02:25:11 kernel: Dead loop on virtual device vlan10, fix it urgently!
sentinelvdx
Go directly to the latest firmware version, no need to apply one by one to the latest.
BUT you'll need to do a hard reset and reconfigure all manually (not using the cfg file). Dead loop was fixed long time ago, but it requires a full hard reset in order to avoid carrying issues from previous firmwares using old settings.
ASUS@SG:
The WPS issue is still there, you can turn it off, but if I reboot WPS turns on 5Ghz band. I have tu turn switch on and off again after each boot.
thiamhui
Download the latest beta firmware from http://forums.hardwarezone.com.sg/93864964-post3390.html for the fix on dead loop issue.
Hard reset will be required.
thiamhui
Huh? Firewall cause WiFi speed to be slow? Dunno... Cos my plan is only 200 Mbps and I can almost hit the speed I'm paying for... :D
carlover76
Just to check whether 160+ is the Max for WIFI we can get from this Router on 1GB Fibre Plan? :s11:
