ASUS Zenfone 2
etherealism
i have this problem, like when i try to make a phone call, it will be totally black screen and no sound, i have to press the power button to hear the other person but during this time, the screen is still totally black.
very very odd. it feels overall very unstable
odd.. is your screen protector blacking the proximity sensor?
after checking that can do the usuals.. update.. factory reset.. if still no game, RMA it
james112
have 2 issues after used for 2 days
1. phone autoshutdown everytime when battery drop to 20-22%.
After wait for a while, it still can be opened and function.
2. home and apps button not in function when using some apps.
kokitty
Go RMA. 10 char.
amelia80
which one huh?
ahhhh must be. i am using a screen protector that does not fit the phone. which one is the proximity sensor huh? is it the one with the orange light?
thks guys...
forumer
These are list of implementations for FW released
Version】
V2.19.40.18_20150612
【Model Name】
ZenFone2 (ZE551ML)
【Release Date】
2015/06/18
【Release Note】
1 Update phone APN version to 105.
2 Update Houdini 5.0.2
3 Fixed camera can not open sometimes when using zenflash
4 Improve volume of recording video will increase and decrease alternately.
5 Do not config Routing.Configure.HWCodec.Playback.Mixers.Headset when using FM.
6 Fixed some BLE device can not auto reconnect
7 Improve service stability
8 Improve modem stability from crash
9 Improve call stability
10 Improve signal bar stability for sim 2
11 Quick Settings: Change "Reading Mode" button as "Bluelight filter"
12 Improve SysteM UI stability and modify Japanese strings
13 Improve lockscreen UI and stability
14 Fix Homescreen Wallpaper randomly lost previous settings and half black screen issue
15 Snap View-add reset Snap View password function
16 Fix Contacts search failure issue when default language was set as HK Chinese
17 Improve Auto start manager stability and fix FB broadcast issue
18 Improve Task Manager UI and rotation stability
19 Fix calculator stability issue and UI bug under Quick Memo App
20 Improve Launcher and Multi user stability from System and framework
21 Fix Google Voice incoming call source issue and the failure to change to Google Voice number
22 Fix the issue that miss call counts failed to disappear on home when Multi user
23 Improve File Manager stability
24 Add ASUS ZenUI PC Suite
25 Fix all touch gestures to be enabled when change back to owner mode
26 Fix ASUS Browser issue
27 Fix the issue that Audio Wizard cannot be launched when turn off BT
28 3rd party app update
29 Update touch FW
30 Update JP IME ATOK to v 1.0.1
31 Modify Japanese strings in Power Saver App
32 Fixed turn on the camera must unlock by using zenmotion issue
33 Fixed an error message shows up after removing privacy mode and adding new user immediately issue.
34 Fixed wallpaper needs to have second clicks for reaction issue.
35 Fixed built-in browser features a new incognito window has no effect issue.
36 Fixed close contacts shows other programs issue.
37 Fixed built-in calendar Click settings will flash issue.
38 Fixed ringtones into vibrate mode when the camera is off camera sounds issue.
39 Fixed volume keys to adjust the ring abnormaliy issue.
40 Fixed wallpaper Figure has been broken issue.
41 Fixed after the system optimization, message management have stopped running issue.
42 Add Battery charging ready reminder feature.
43 Enable FM Radio for Turkey
bladez87
Version】
【Model Name】
ZenFone2 (ZE551ML)
【Release Date】
2015/06/18
【Release Note】
29 Update touch FW
Don't dare buy export set seeing so many people rma
amazingone
Sent from Xiaomi MI 4I using GAGT
t258jgn
Help! Is ZenFone 2 designed in such a way that if the first notification be it sms or whatsapps was left unread, the subsequent notifications be it sms or whatsapps will NOT have any notification sound?
I have the same issue also. No notification sound
