Lucky177
- Jul 1, 2002
Glad u have resolved it.Anyway I went to rma it. Turns out that it is fuser problem. Mechanical problem. Got it replaced.![]()
Sent from Android Mobile using GAGT
1. Mono
2. Print Scan Copy (3in1)
3. less than 100 page
4. max $200
5. wireless is plus point, although if price too expensive, can forgo.
best if can put where to buy too![]()
Thos 2 u recommend is print only, dont have scan and copy. You can look at
Fuji Xerox M115w $99 now at Funan atrium challenger members event
Print Copy Scan Plus Wireless
Toner $42 for 1k pages
drum $49 for 12k pages
If you need duplex then look at this
http://list.qoo10.sg/item/FUJI-XEROX-FUJI-XEROX-MONOCHROME-LASER-PRINTER/429211972
M225dw got drum under warranty better but of course depends if you need the duplex printer and ADF feature.
U should still stick with a basic monochrome printer leh, since u still need to print lots of journals.I've bought two separate laser printers as I've heard it mentioned before that it is more economical. However, it has become a hassle to have two machines, PLUS a photo printer..
I would like to combine the mono & colour laser printer (with scanning abilities, duplex print & scan).
I print more mono documents, and need it to be economical as I am in the research field and print lots of journals.
Have been using Fuji Xerox printers and very pleased with results & price of toners (oem). Anybody has a recommendation? (other brands are fine)
thanks for the recommendation.
I'd need to wait for future roadshows by Challenger, as the 1 at funan is until 30 August, and I've got no time to head down.
Can check ion orchard received info that 4 August will have Challenger roadshow again![]()
upgrade to win 10 now my shared printer cannot work with my XP computer![]()
wait for courts sale usually they sell samsung basic laser printer for $59 or $69
Hi,
Need help with my Fuji Xerox printer CM215FW.
The black printout is very fade. Have tried different sets of toners and the outcome is still the same.
Anyone can recommend someone who is good in repairing Fuji Xerox?
Hi guys, thank you for the advise.
Quite sad to discover there isn't a one-printer solution![]()
Now my next question is what are the cost differences or differences between just a mono printer and those combined with colour ones, the black toner is not seperate?
