[Printer] Laser Printer questions lip lai !!!
tonerseller
1. Mono
2. Print Scan Copy (3in1)
3. less than 100 page
4. max $200
5. wireless is plus point, although if price too expensive, can forgo.
best if can put where to buy too :)
Thos 2 u recommend is print only, dont have scan and copy. You can look at
Fuji Xerox M115w $99 now at Funan atrium challenger members event
Print Copy Scan Plus Wireless
Toner $42 for 1k pages
drum $49 for 12k pages
If you need duplex then look at this
http://list.qoo10.sg/item/FUJI-XEROX-FUJI-XEROX-MONOCHROME-LASER-PRINTER/429211972
M225dw got drum under warranty better but of course depends if you need the duplex printer and ADF feature.
Thehim
thanks for the recommendation.
I'd need to wait for future roadshows by Challenger, as the 1 at funan is until 30 August, and I've got no time to head down.
Evielicious
I've bought two separate laser printers as I've heard it mentioned before that it is more economical. However, it has become a hassle to have two machines, PLUS a photo printer..
I would like to combine the mono & colour laser printer (with scanning abilities, duplex print & scan).
I print more mono documents, and need it to be economical as I am in the research field and print lots of journals.
Have been using Fuji Xerox printers and very pleased with results & price of toners (oem). Anybody has a recommendation? (other brands are fine)
Kiwi8
Deluxe Member
U should still stick with a basic monochrome printer leh, since u still need to print lots of journals.
tonerseller
Can check ion orchard received info that 4 August will have Challenger roadshow again :s13::s13:
tonerseller
Yea stick to 2 printers will be more economical. At least can have 1 back up should the other break down. Mono printer CPP is always way better then color AIO.
initialtbk
Hi all, looking to get a printer to print mainly text documents. Student here so looking for a printer that is economical especially for ink consumption and price.
Some requirements:
1) Decent to good print quality of text as i'll be mostly printing lots of notes and articles.
2) Black and white should be sufficient but colours are welcome if price is acceptable.
3) I will be printing double sides so duplex is a plus point but don't mind manually flipping pages to print duplex if duplex machines are too expensive.
3) Wireless is a must. Although don't need Airprint or google cloud print as will be printing from laptop.
4) Ink refills should be affordable for a student. Good amount of print per cartridge.
After doing some searching online, I came across EPSON L355 which fits most of my criteria especially the ink tanks and $9.90 per ink bottle, up to 4000 pages per black ink refills. But my concern is the printout quality(sharpness) of the text as I would be printing rather small fonts, i believe its an inkjet printer and read some reviews that the text are not sharp. Slightly exceeds my budget of below $300 too.
Any feedback and recommendations for other printers or L355 are welcome!
Evielicious
Hi guys, thank you for the advise.
Quite sad to discover there isn't a one-printer solution :(
Now my next question is what are the cost differences or differences between just a mono printer and those combined with colour ones, the black toner is not seperate?
blackmagic
Hi,
Need help with my Fuji Xerox printer CM215FW.
The black printout is very fade. Have tried different sets of toners and the outcome is still the same.
Anyone can recommend someone who is good in repairing Fuji Xerox?
mosmos
High Honorary Member
wait for courts sale usually they sell samsung basic laser printer for $59 or $69
raindance
Is the M115w still available at $99? I looked at challenger website seems like there isn't any event at funan atrium now?
Mr.Eric
Hi, please suggest a printer for printing digital drawings
1. Mono or Colour
- Colour
2. Print Scan Copy (3in1) or single function
- Single function printing will suffice
3. Printing capacity per month
- Around 100
4. Budget
- Below $300
- Reasonable cost of consumables
5. Other extra requirement like wireless, iphone printing etc.
- Wireless is a bonus.
Thanks!
Ohayo!
upgrade to win 10 now my shared printer cannot work with my XP computer :s22:
tonerseller
Hi,
Can call their service side, 18003565565 This one is drum problem.
tonerseller
just mono printer only CCP ranges from 2 cents to 3 cents
For color ones, CPP ranges from 2.8 cents to 5 cents
