tuntun
Dear all,
RT-AC87U_3.0.0.4_378_8248
Fix French UI
Fix bugs
New: Enable Traffic Analyzer
Update: IPTV ISP profile setting of 'movistar' & 'meo'
Update: Quantenna SDK: v37.3.0.50 (acR3.2.1)
Update signature into 1.066
Update: dnsmasq: 2.75
Update: openssl 1.0.2d
Update: adjust the maximum number of Guest Network MAC filter. (16 client per Guest network)
Fix: 5Ghz AP isolate issue
Fix: Allow $, ",` and \ in SSID and WPA-PSK for Quantenna
Fix traffic monitor issues
Update Extend max VPN clients to 30 for high-end models
Fix: [Adaptive QoS] [Bandwidth Limiter] less than the actual speed setpoint
Fix:[AiProtection] turn cause the machine to reboot repeatedly endanger website
Fix: [USB Application] USB HDD can not mount
Fix: [AiProtection] Parental controls time scheduling blocking message can not be displayed
Download: http://goo.gl/zdcNK6
Please feedback to me if you encounter any issue.
Require: Restore to factory default.
Best regard,
JK
any upgrade for RT-AC68U with ver 3.0.0.4_378_8248???
joe_lee_sg
3.0.0.4.378_8248 5Ghz Beamforming ?
Updated the firmware with beamforming, however seems to be getting high ping and slow speed with 5Ghz band.
Disabled beamforming and speed back to expectations.
Is beamforming still broken for the 5Ghz?
sentinelvdx
So far I've found a GUI issue when I select "AiCloud" Tab, it shows "USB Application" as selected instead, so I need to go to another tab in order to access "USB Application" one.
Well, and WPS issue is still present.
Later I'll continue testing it deeper.
ankhazam
Well I found an issue with my ISP WAN.
I got a typical PPPOE connection (user&pass) to assign me a dynamic IP.
The case is that with this configuration my IPV6 DHCP-PD which should be distributed over the PPP tunnel doesn't work.
My ISP provider told me that I should set DHCP-PD with ::2/64 pool and the router should be able to autoconfigure.
Therefore I set Native IPV6 with DHCP-PD enabled on PPP interface and stateless configuration and it fails to works :( Tested on 7177 and the latest 8248.
poor_poor
Which build is working for you?
runestyx
Dear all,
Fix French UI
Fix bugs
Best regard,
JK
Is this a beta?
carlover76
Dear all,
Fix French UI
Fix bugs
Best regard,
JK
Can I upgrade to this firmware from current 7410?
thiamhui
Dear all,
Fix French UI
Fix bugs
Best regard,
JK
Can see many improvement on the GUI...
But sad to say, most of the issues at 5GHz are still there. Like Beamforming, WPS, battery drain and maybe MU-MIMO. :s22:
shaobing_1010
Dear Carlover,
Yes, but you need to do reset to factory default settings after update the firmware.
Best regard,
JK
Dear JK,
I updated the 8248 firmware! Also adopted a hard reset the router. But I found that after I use 2wan, plug in the router installation Thunder offline download files will appear automatically restart the phenomenon of 1-2 hours. I do not start the Thunder widget is still being tested. Unclear firmware files or plug problem!
Also you can read Chinese?
Best regard,
Shaobing
ASUS@SG
Suspended
Dear JK,
Best regard,
Shaobing
Dear Shaobing,
I can speak, but cannot read and write :(
Because too many lines in one single word, so I give up! hahaha i perfer english.
Best regard,
JK
BobbyTan
Updated AC87U to FW 8248 follows by hard reset. AC87U acting as bridge refuses to connect to the main AC87U router. Fall back to 7449 is all is good.
ASUS@SG
Suspended
Dear Bobby,
Did you update both routers to the latest firmware?
Best regard,
JK
ASUS@SG
Suspended
Well I'm at 8248 currently, I only tried to run it on 7177 and 8248 as I switched ISPs recently and the new one provides native IPV6 over DHCP-PD over PPPoE.
regards,
Ank
Dear Ankhazam,
Please try below settings.
IPv4->PPPoE with the user&pwd ISP provided
IPv6->Native
Best regard,
JK
ankhazam
Dear Ankhazam,
IPv6->Native
Best regard,
JK
I know, that's exactly what I have set it set to it doesn't get the IPv6 address :/
My syslog
Aug 1 02:00:25 pppd[470]: pppd 2.4.7 started by admin, uid 0
Aug 1 02:00:25 pppd[470]: Connected to [Some MAC here] via interface eth0
Aug 1 02:00:25 pppd[470]: Connect: ppp0 <--> eth0
Aug 1 02:00:25 pppd[470]: CHAP authentication succeeded
Aug 1 02:00:25 pppd[470]: peer from calling number [SOME MAC HERE] authorized
Aug 1 02:00:25 pppd[470]: local LL address [fe80::***]
Aug 1 02:00:25 pppd[470]: remote LL address [fe80::***]
Aug 1 02:00:25 pppd[470]: local IP address [IP]
Aug 1 02:00:25 pppd[470]: remote IP address [GW IP]
Aug 1 02:00:25 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
the time is pre NTP after device reboot but it was today.
Important note:
My ISP only told me to set ::2/64 as the address pool though I don't understand where to put it in the GUI.
poor_poor
My syslog
Important note:
Which country are you from?
