u got see the rest from hwz? I think some tech bloggers also got write?
Anyone have ideal can this device support Singtel 500 mbps plan?
I last time a router end up can work with Singtel 100 mbps plan?
Anyone can advice
definitely can work with singtel 500mbps. but you need to update its firmware to the latest one.
since it was only released not long ago, the stocks you buy on shelf might still run the older firmware..
Wah Renfred u very good lei all these u also know... u work for them is sit? U got use their products?
Nope I didn't use dlink for a long time. The information can be obtained from dlink support website, so appreciate my effort that I took the time to check for u all..![]()
same here.
running on firmware FW:1.01SG from D-Link SG website.
Enabled VLAN -> Set Internet VLAN 10, IPTV VLAN 20.
Set Port 4 to IPTV. Plug Mio to Port 4. All set!
Smart Connect works well so far. Will continue testing.
alpha, can share with us your testing results all?
Will do some testing tonight. What sort of tests are you looking for specifically?
My AC devices is only the MiTV and my iPhones. But will be comparing existing devices compared to my Asus N66U.
I still noob... but just wonder if it makes a difference in different house setting. Mine's old hdb flat and I place spider at corner of my TV console... not really centralised but heng not much concrete wall...
The best is now I go toilet in kitchen still can watch youtube... lol!!!
Yo guys, so I'm writing out like what happened to my Dlink 890L.
So basically, I'm on Starhub Cable Internet lah, and then one fine day, my Internet suddenly disappeared. Upon inspection, I believe that my router is faulty, since direct connection to modem works.
Called Dlink Support, which was horrible. They spoke with thick accent and could not really understood me. Over the course of 2 days, keep asking me reset my router.
Finally got escalated to "Level 2" technician, who actually didn't know much, other than tell me to flash 1.07 firmware, then RMA.
Went to Dlink service centre at Jurong and 1 for 1 exchange. Now its working quite well and I'm pretty impressed with their support.
