[Maylyn's Review] ASUS RT-AC3200 Router
Apparatus
Dear all,
Please do a factory reset after update the firmware.
Best regard,
JK
Factory reset means erase all my settings. I got so many WiFi devices means I need to reset everyone again? If every firmware upgrade needs a factory reset then wah mah see beh boh eng?
Is it possible to copy(export) out the configuration file (or such) then do a factory reset after which import the configuration file into the router so as not to go through the whole process of connecting each and every device again?
ASUS@SG
Suspended
Dear Apparatus,
Why do you need to reset all your wifi device?? Just name the same SSID as the old and your device will automatically connect.
Best regard,
JK
Apparatus
Dear Apparatus,
Best regard,
JK
I don't get you. I thought factory reset erases all settings in the router?
Using Smart Connect means the router will auto connect to each and every device without even depressing their WPS button?
In my early DLINK routers there's provision to copy(export) out its configuration file with all devices' settings and then import the file back after a factory reset of the router. Here I have no need to re-key all the detail of every device again
ASUS@SG
Suspended
Dear Apparatus,
Let me give you one example.
Old configure SSID: Apple
Password: Apple
New configure SSID: Apple
Password: Apple
If you restore to factory settings and you enter the SSID and password is same as previous SSID and password, then you don't need to connect device manually connect to the router.
Best regard,
JK
Apparatus
Dear Apparatus,
Password: Apple
Password: Apple
Best regard,
JK
OK thanks. It works but still a bit slow
Apparatus
Re
Hi ASUS@SG
Just to check something.
If later I upgrade my router to the ASUS RT-AC5300 from my current RT-AC3200 and using the same SSID and password as previously would all the devices in my house be automatically connected. Or do I need to start all over again by connecting each and every device to the new router?
ASUS@SG
Suspended
Hi ASUS@SG
Dear Apparatus,
Yes :) Same SSID & Password and your device will automatically connect.
Best regard,
JK
hnzfaz
Hi ASUS@SG
I'm using singtel fibre service (high-end plan) at the moment. My modem/router is an aztech set that was supplied by singtel. Recently it seems to be giving me some problems, and I'm looking to upgrade to a better modem/router.
Which Asus model would you recommend?
I'm not tech savvy, so the most important criteria for me is the ease of installation. Would I have any problem with installing the Asus router as a newbie? Seeing page after page of technical issues in this thread really makes me worry. :)
Thanks.
SongManKranji
High Honorary Member
Hi Asus@SG
Will there be significant improvement from AC68U to ASUS RT-AC5300 :D
hnzfaz
Hi Asus@SG
Just in case you missed it, can you please reply to my post #589 in this thread? Just a few posts up.
Thanks.
ASUS@SG
Suspended
Hi ASUS@SG
Thanks.
Dear hnzfaz,
Which singtel plan are you using?
Best regard,
JK
ASUS@SG
Suspended
It's 1Gb fibre broadband.:)
Dear Hnzfaz,
I would like to recommend you RT-AC68U or RT-AC3200.
If you are unsure regard of setup and you can always contact avertek service hotline and they will assist you.
Best regard,
JK
ASUS@SG
Suspended
Ensure your digital playground is safe. With AiProtection, lessen the risk of your confidential information being stolen, and a warning mail will be sent to you if any malicious server is being detected!
Protect your home network now!
For more information: https://www.asus.com/sg/Networking/RTAC3200/
GunPriest
Hi guys,
I recently upgraded to AC3200 and StarHub 1gbps plan. I did a speed test at 2m away from router and result was 200-300Mbps (download) and 300+Mbps (upload). Improvement was not much different when compared with old D-link AC router on previous StarHub 300mbps plan.
My router f/w is 7838 which I updated yesterday. Any solution to improve the speed? Thanks.
renfred89
Hi guys,
the latest firmware is 9135. download from the support website instead of using the built-in upgrade function..
ASUS@SG
Suspended
Hi Asus@SG
Will there be significant improvement from AC68U to ASUS RT-AC3200 :D
Dear Gloom,
Dear Gloom,
Yes, but do you need such a fast router? It's also depend on your client and internet plan.
Best regard,
JK
