shaobing_1010
Dear pepeEL,
We are waiting for the new driver to resolve the issue.
Best regard,
JK
Dear JK,
9177 firmware exist BUG, when enabled 2WAN, if a "firewall" enabled - "Enable DOS protection" will lan port and wifi free access to the emergence of the Internet! Please be corrected!
2. Download Master when adding the seed file, and then add one will disappear
3. When will the next version of the update? please inform
best wishes
Shaobing
ASUS@SG
Suspended
JK
Had a question posed in another forum maybe something to consider for future firmware ? is this something easily achieved ?
@ Merlus writes...
["Can anyone tell me if I can use 30 minute increments for the time scheduling under parental controls?"]
["I want to disable my kid's internet access at 9:30 PM during the weekdays, but at the moment I can only set 9 or 10 PM."]
["Is it possible from command line or maybe the merlin firmware?"]
Dear Praxos,
The time scheduling only allow by hour.
Best regard,
JK
VANT
its normal ? No traffic no client but we see traffic on chart....
h**p://s25.postimg.org/dfx22e7qn/tabug_10.png
for me TA is totally broken....sometimes show clients sometimes not, and i don't know what is exactly show TA, what traffic ?? Its not traffic per day, so what ??
next example
first enter in TA, we see traffic chart
h**p://s25.postimg.org/kkjgp64dr/ta_1.png
next i only set date to same date and we see totally different traffic chart
h**p://s25.postimg.org/klteil67j/ta_2.png
anybody can explain me what TA work ??
ASUS@SG
Suspended
next example
Dear VANT,
I do not have ant eye... Your image is too small for humans to see.
Best regard,
JK
ASUS@SG
Suspended
Dear JK,
best wishes
Shaobing
Dear Shaobing,
There is no ETA for next firmware to be released at the moment.
Best regard,
JK
pepeEL
And but not reply for me on forum and priv. Send you file and nothing. Send you bugs and suggestion and other user also and nothing... Ehhh
VANT
Dear VANT,
Best regard,
JK
images have 640 pixel resolution...its too small ?? I can make bigger if You need.
maybe You not change ** to tt in images adres ? I cant post images becouse my post count is too low...
Thx for reply
pepeEL
next example
I also have this problem and send to ASUS but Asus nothing do...
NOTHING
Battery on android still drain on 5GHz... and we still waiting for drivers... ehhh stil and still
snowsakgr
An auto-update antivirus signature would be nice.Theres a compability issue with ADATA HDDs they wont use power management features will be active 24 hours only when they formatted to NTFS.Except that the router is working perfect still no battery drain at least for me.I got connected an Asus Tranformer T100TA(5G),Samsung Galaxy TAB4 7"(5G) and a Nokia 1520(5G).
VANT
Oct 8 21:59:59 ntp: start NTP update
Oct 8 22:00:01 ntp: start NTP update
Oct 8 22:59:57 ntp: start NTP update
Oct 8 23:00:01 ntp: start NTP update
Oct 8 23:59:57 ntp: start NTP update
Oct 9 00:59:57 ntp: start NTP update
Oct 9 01:59:57 ntp: start NTP update
Oct 9 02:59:57 ntp: start NTP update
Oct 9 02:59:59 ntp: start NTP update
Oct 9 03:59:58 ntp: start NTP update
Oct 9 04:00:01 ntp: start NTP update
Oct 9 04:59:57 ntp: start NTP update
Oct 9 05:00:01 ntp: start NTP update
Oct 9 05:59:57 ntp: start NTP update
Oct 9 06:59:57 ntp: start NTP update
Oct 9 07:59:57 ntp: start NTP update
Oct 9 07:59:59 ntp: start NTP update
Oct 9 08:59:57 ntp: start NTP update
Oct 9 09:00:01 ntp: start NTP update
Oct 9 09:59:57 ntp: start NTP update
Oct 9 10:59:57 ntp: start NTP update
Oct 9 10:59:59 ntp: start NTP update
Oct 9 12:00:01 ntp: start NTP update
it's normal that router synchronize time every hour ?
Jong99
Hi ASUS@SG,
Does Asus have any thoughts on the iPad Air2 disconnection issues? Are you telling Apple they have something to fix or is this on Quantenna's list?
pepeEL
ASUS@SG look...
RMerlin fisrt add option to edit virtual ports....
https://github.com/RMerl/asuswrt-merlin/commit/a3be3befc4d37e4b56b29927f0ea9204e43edcca
and
https://github.com/RMerl/asuswrt-merlin/commit/2b53f9867c5e9499a44031825c95d76dd15076d3
Also better edit DHCP list
https://github.com/RMerl/asuswrt-merlin/commit/6342415af142630d4c6f399df2e524d9204eb7b5
next very important issue fix:
https://github.com/RMerl/asuswrt-merlin/commit/95e0bcbe9e651f0d3111e344bb647fb27e277be8
One person but do more and more job than ASUS.
But ASUS still not add , despite of request users.... Ehhhh
Asus has many developers and RMerlin is one person.... and the effects are visible every moment in its software.
That's bad demonstrates ASUS
My request and resolved issu(by send edited file) to add provider GSM for Poland - AERO2 still not add.
I gave a ready solution and also ASUS does not make it.
VANT
Dear VANT,
Best regard,
JK
Thx for reply
i reply to You about my screenshot, so what can You tell about this pictures ?
