WussRedXLi
- Jun 15, 2001
Akai ryu, my CEM ndIR meter tonight arriving ba....lets see how we fare tonight in our HDB room.
Wah lao, ask the boss to dont pack like that lah. Waste weight.
I like how you hang it.
lol
Is there another way? I got mine the same way haha
Ok, it's this seller. SOme of the sensor stuff that he sells like TVOC, CO2 is pretty "high-end", more than enough for home use.
https://wclh.world.taobao.com/shop/....7700714.0.0.EqmW2t&user_number_id=2375177132
Thanks. I thought you were recommending Samo Air in the previous posts.
Now got new contender. Anyway, all are using Plantower G1. So ok. The module is outputting the data digitally, so the difference is in the module, not the PCB/decoding. eg doesn't matter what brand of resistors or capacitors the PCB is using, it's all decoded by a chip and displayed on the PCB.
Try to get the one with the particle count, geek mode ba.
I can't find the one from Insan Tech from Taobao shown in your posts.
This is my CO2 data fr last night.
Started at 518ppm moderate range. Noticed that i have yet to receive good CO2 range even when room is aired b4 windows closed for AC.
Switched on AP at same time...Sharp shower auto 1 hr. Noticed how fast the CO2 climb to the 900ppm range within abt initial 30mins. Basically stayed at the not good range till wake up.
