renfred89
Does the 87U work with MIO TV Vlan tagging? If so which port?
Does the newest firmware support MU-MIMO?
Thanks.
Obviously you never the few posts below..
Mu-mimo is enabled in firmware 9177, and it does support singtel tv. It's port 4 if u choose the preset profile.
frav_se
"You do not have sufficient post count to post images/links" says the forum.
So add http & replace _ with dot
www_snbforums_com/threads/official-rt-ac87u-firmware-version-3-0-0-4-378-9313.28034
ASUS@SG
Suspended
ASUS RT-AC87U Firmware version 3.0.0.4.378.9313
Security improvement
- Fixed User-Agent buffer overflow. Special thanks for Hubert's contribution.
- Fixed null ptr dereference in https issue. Special thanks for Anthony's contribution
- Fixed buffer overflow issues.
- Modified brute-force protection mechanism in router login page.
- Fixed malicious site block related issues.
New Feature
Support ASUS router app which make it very easy to monitor and manage route status and client devices and more.
Search ASUS Router in google play or go the following URL
https://play.google.com/store/apps/details?id=com.asus.aihome
iOS app coming soon.
Bug Fixes
- Fixed httpd crash issue. Special thanks for Merlin's contribution.
- Fixed blank web page when clients number over 100.
- Fixed Network map client list related issues.
- Fixed firmware login issue when connect to router by OpenVPN.
- Add reboot scheduler in Administration --> System
- Fixed warning page showing issue when only enable the HTTPS authentication.
- Fixed the slow UI issue when enabled Bandwidth limiter.
- Fixed repeated mDNSNetMonitor message in system log when there is a Apple TV in LAN.
- Fixed IPv6 firewall UI issue.
- Avoided Traffic analyser using too many flash size.
- Fixed UI issue when enable monopoly mode in printer setting.
Download: http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC87U/FW_RT_AC87U_30043789313.zip
mikengtw
Very interesting look like the new firmware getting all the bugs fix.. hope
the temperature won't be so hot .. and Asus did a good job on patching up.
DriftKing
I've posted across samsung user forum and I'll post here as well because i'm not too sure the cause, I've updated both my phone S6 and latest (9177) firmware for the router and experience noticeable battery drain for the first time.
renfred89
try 9313 firmware..
Cypher
Guys,
Need some help. I have upgraded from 200Mb to 1Gb fiber unlimited and the activation was supposed to be done today between 330pm - 500pm.
Last night around 12am, my fiber line and digital phone line was disconnected. My digital phone line is connected directly to the black ONT box.
I have tried re-configuring my AC87U WAN setup to be on Automatic IP (no tick on the special requirement from ISP) but I still can't get connected to the internet.
I tried connecting a direct cable to the ONT port 1 and was able to connect to the internet.
Any idea on how I should configure my AC87U?
Thanks.
xonix
Guys,
Thanks.
Sometimes for customers going from plans which required vlan tagging, SingTel backend did not remove tagging when upgrading to 1Gbps. Try activating the SingTel-Others profile and see if it works. Else, you have to contact their tech support liao.
blue01
Guys need urgent help please.
I'm doing wireless lan for multiple xbox. I can see the game listing but cannot complete the joining. Then I tried cable connection to router and it worked.
So there must be some wireless settings not setup correctly. Can help?
renfred89
Guys,
Thanks.
Try resetting the router..
maylyn
Guys,
Thanks.
SingTel 1Gbs plan are supposed to connect to your SingTel ONT Port 2, and automatic IP selection. VLAN profiles are not required.
maylyn
An achievement in the making in my ASUS RT-AC87U thread after 4797 replies and over 1 million+ views (1090076 to be precise and counting) :D ;)
Thank guys ^^
I guess there are haters and peeps whom are loving it and the ASUS RT-AC87U serving them well.
+ fair share of trollers and rival router users that are disguised as an ASUS RT-AC87U user.
Nevertheless, ASUS TW will continue listen to feedback/suggestions and make the best routers in the years to come ;) We are here to stay ^^
PS ~> please update your ASUS RT-AC87U to the latest version if you haven't done so.
New Feature
Bug Fixes
andyqkw
Aevertheless, ASUS TW will continue listen to feedback/suggestions and make the best routers in the years to come ;) We are here to stay ^^
Make more like the Asus OnHub (without all those ever increasing freaking antennas sticking out) and bring them to Singapore.
It's a shame that most never ever made it here...
VANT
i check my 87 temp. and i see 64C :eek::eek::eek:
Code:
VANT@RT-AC87U:/tmp/home/root# cat /proc/dmu/temperature
CPU temperature : 64▒C
VANT@RT-AC87U:/tmp/home/root# qcsapi_sockrpc get_temperature
temperature_rfic_external = 0.0
temperature_rfic_internal = 57.6
temperature_bbic_internal = 55.0
earlier i have 10C more (when i use merlin fw). I use active cooling pad with very slow fan
For me its very good job from Asus.
