[Maylyn - Networking] ASUS RT-AC5300
guards80
I am now running on 5Ghz-2 wireless bridge with smart connect off. No dc since day 1
yes i also nv get disconnect too. and speed on note 5 using 5ghz-2 DL400+ UL400+ very fast.
hmm 5ghz like abit drain battery last night 11pm have 90percent. wakeup morning 7am battery left 50percent.
wwyjoe
Any bros can share if the AC-5300 has better 2.4ghz range compared to the AC-3200? Thanks
saj282
Went down to Sitex hoping to get this router but only to find it completely sold out at all outlets; even pre-order has ceased 😞. There must be a very huge demand for it.
Guess I hv to try X8 instead.
guards80
Time to join in the signal strength party :s13:
Measured using A8, which is known to be a wickedly good wifi receiver :eek: 2m away from mighty AC5300
First up 2.4G Channel 11
Next up 5G Channel 36
Lastly 5G Channel 149
wow your 5g-1 and 5g-2 very strong and my 2.4g same as u... mys both 5g very week set same channel as u and 2M away unblock using Note5
guards80
Here is some speedtest on 5G Smart Connect 2m away from router using Samsung Note 5
guards80
hmmm do anyone know change region on wireless will increase TX power?
saw in at sbf
According to posts (in Simplified Chinese) from this early adopter, the stock firmware allows users to switch "regulatory region".
http://www.chiphell.com/forum.php?mod=viewthread&tid=1414275&page=1#pid31304018
With different region setting, he found the below txpwr_target_max values:
US 24
Singapore 14.75
Asia, Australia, China, Europe, Korea, Russia 10.5*
Apparently he is only checking 2.4G txpwr values, might be indicative of what happening on 5GHz though. This perhaps explains why the other user saw poor 5GHz performance.
Seems the firmware at the moment is only polished for US.
Apparatus
Re
Aiya, my SC is on the 5GHz 2-band connection only and I have 2x5GHz devices and 3x2.4GHz active only
Don't know why all of them are connected to the 2.4GHz band. All are having the same SSID
SimonLam
Moderator
Moderator
Again? I think you need to read carefully what other forum members had advised you earlier.
coolnhappy
saw in at sbf
US 24
Singapore 14.75
Don't think increasing tx power will change performance much. After all, you need to increase received signals. For me, I changed the antenna and both tx and received signals improve tremendously.
guards80
what antenna you have changed to? all 8 antenna u have change?
coolnhappy
I just changed one. It is an extremely high gain antenna that I bought in CommuniAsia, from one of the Chinese booths. Normal Wifi antennas have a gain of about 2dBi but this one boasts of 14dBi. Just imagine 12dB improvement in gain! As of now, inSSIDer shows that my received signal is -26dBm.
guards80
i thot is super power supply antenna. wow that good. -29dbm is which band? how far from router?
