NamelessOne
- Dec 1, 2015
Dear all,
I'm in need of your help, I have the RTAC87U for 3 months and was working great until just 2 days ago when the 5GHZ radio started to behave very strangly.
It began rebooting automatically and the 5GHZ Led would not light up. After a cold reboot it worked... for 1 more day.
The next day suddently rebooted itself again but when it came up the 5GHZ LED light would not light up, the LAN1 port LED blinking is really weird and it would not work anymore, LAN1 is dead.
Also the Wireless General TAB is messed up.... I can't attach a screenshot due to insufficient post counts.
The whole configuration page has all but gone,
with no tabs anywhere and just a single pane in the middle of the screen on which I
can't do anything and I have to reload the router main page in order to regain access.
I'm on firmware 3.0.0.4.378_9313
What I have tried:
3.0.0.4.378.9177, hard reset, same problem: 5 GHz radio is not ready, LAN1 port not working
3.0.0.4.378.5134, hard reset, same problem: 5 GHz radio is not ready, LAN1 port not working
3.0.0.4.378.4950, hard reset, same problem: 5 GHz radio is not ready, LAN1 port not working
3.0.0.4.378.4608, hard reset, same problem: 5 GHz radio is not ready, LAN1 port not working
now I'm back to 3.0.0.4.378_9313, hard reset, same problem: 5 GHz radio is not ready, LAN1 port not working.
I have also tried Merlin but no luck as well. Trying to telnet to the router and upon investigating I think I've found that the Quantenna is not booting. Not sure if this can be fixed or not. I'm beginning to think it's hardware related
I'd appreciate any help.
Thanks
What I have tried:
Thanks
