iV3RsOn
- Dec 16, 2003
shoot bird, bird shoot bird kym?
Possible for the bird to fly that way after kena shot?
Please don't stir the mods. They are just doing their jobs.
You can ask for recommendations and share suggestions in this thread.
However, if you ask forum users to PM you so that you can sell them stuff, then that it considered as Unsolicited Content.
Any buy/sell transactions should be done in the bazaar/marketplace. Simple as that.
The reason why we are so strict lately is because previously we do not have enough mods to watch over this section of the forum and a lot of people have been masking their advertisement as suggestion/recommendation.
Hope that clarifies.
Hello, can recommend me hairstyle for men? Like short sides and long top
pompadour luh. Im leaving my hair longer to try braided. something like that
http://i.dailymail.co.uk/i/pix/2012/09/30/article-0-1545FA61000005DC-750_634x704.jpg
NOT THE THIN ONES
You need a pre-styler, and a strong but light weight product. Prestyler can use sidekick or a sea salt spray, wax or clay can consider dynamite clay or mm. Both are lightweight but strong hold. Good for thinner or finer hairhi guys! my gold digger is running out soon, and I'm thinking of trying other new products. It's not that the gold digger is bad, it is DEFINITELY better than Gatsby, but my problems are:
1) everytime I blow dry, hair gets soft, and when I apply the wax, it just doesn't seem to hold?
2) hair doesn't seem to hold that well despite how much wax I apply. apply at home, swee. once reach school, my hair drops.
oh, and my hairstyle is somewhat like a pompadour.
any other products to recommend?
Sent from 象牙塔 using GAGT
what is mm?You need a pre-styler, and a strong but light weight product. Prestyler can use sidekick or a sea salt spray, wax or clay can consider dynamite clay or mm. Both are lightweight but strong hold. Good for thinner or finer hair
Sent from TGS using GAGT
Morris Motleywhat is mm?
can consider the dynamite clay. what's the difference between that and gold digger? more lightweight?
Just ask for undercut, slick back from your personal hair dresser.
where to get loreal techni art wax and hair spray? Are they only available in salons?
spoken like a true clone trooper
I went to Watson and Guardian at Taka. Dont have. Only the Studio line.Watson have.
Disclaimer: I not affiliated to Watson or whatsoever
Pruss Satu!
Asking for reconsiderations for haircut here without posting your picture is meaningless. You will get better reconsiderations goggling best haircuts for men 2015.
Best solution is to not cheap out on a hair stylist, find someone you trust and work with them for the best haircut for your face shape.
