Sony Xperia™ M5
localbus
could it be the dual sim model? mine is single sim (touch wood) so far no issue. those M5 they using dual sim as well in HK?
Maybe only for dual SIM..... but i check other forum. the single SIM also have this problem...
IappMusic
Recently I also encounter the auto shutdown issue.it just went totally dead unable to restart even after hitting the reset button.Only way to reboot is to connect to charger it restart with wrong date& time.qyite irrtating imagine if outside and no way to coonect to charger.
Have any user that experience the same problem contacted sony service center abt this issue any way to resolve?
spoon
may i ask your's is single or dual sim?
takizawa
I have the auto shutdown issue n phone has been with svc ctr for more than 2 weeks..
How is it acceptable for a phone to auto shutdown, and cannot be powered on without charging? And the battery life is not as fantastic as advertised.
revolute
I have the same shutdown issue and send my phone to service center. From what i saw on gsarena both dual sim and single sim is affected. I had shutdown of at least 10time. Some say it was due to lte and switch to gsm would solve the issue but i not that sure. Another problem i have is the camera is not available. I thnking of asking for a upgrade to another model if my phone come back with the same issue otherwise i would just trade in the phone for a z5p.
takizawa
My repaired phone came back with the same issue. They cannot offer upgrade, but can try refund. Better than sticking with the piece of junk. Perhaps we should raise this to case on the lemon law?
revolute
I just receive my repaired phone. Only change it did was reloading to software. What is the repair done on your phone for those who send their phone to service
localbus
Going to sell the dual sim one.. can't take it anymore.. shutdown almost everyday now...
Any buyer ?
spoon
i suspect the shutdown could be due to the memory card , recently I encountered it as well which need to plug to the power supply to power on it back..
but after some testing it still having the same problem....
after reset to factory setting it seem behaved normal again ... for now
send in for repair this morning
spoon
so recommended to get this phone? looking to get the dual sim gold
just buy iPhone ha.... personally i don't recommend Sony phone after this.:s13:
most likely would be my last Sony smart phone and I hate Samsung.
update: today collected the phone was told they have changed the battery.
ASummerDay
Read from other forums the course of the shut down is due to the battery, after replace of the battery no more shutting down issue. Kindly confirm since your set also changed battery do you still facing shutting down issue.
Thanks
spoon
Thanks
my phone was working fine for months and it started to have this shutdown thing since Nov , since returning from service centre no shutting down but need to monitor as it happened intermittently before.
update : noticed something different after repair , my stock camera app using manual mode between take always very lag but now seem very fast.
Elnin0
Just checked Sony website. M5 dual is coming soon. When? Worth to buy?
Chisel
Saw it listed online at $480 with model E5663 Sony warranty set.
Keen too but worried about the faulty battery assembly still.
Elnin0
S'pore? I only saw in Malaysia and quite expensive.
where? which shop?
