jq75
- Dec 5, 2000
ehh y apps install so slow? i c all stuck at loading, paused all but one still nt moving...
faced this after update to 9.2.1
Restart phone. Mine also like that. More and more issues.
You might also spot a trend with regards to stopping and resuming downloads by tapping on them, will result in the progressive circle notion to be always in the same few positions like 1/3 or 2/3
.Generic suggestion. Don't install too many apps. Seriously. My own rule of thumb is if I've not used any app at all for the last 6 months, I will delete it. Anyway can always download again. You'll be surprised to know that too many apps can cause issues.
sianz...Very Glad there is this community here informations on Apple devices .
Recently I got myself a iPhone 6s+. And I genuinely need help as I'm experiencing problems. Bringing in for exchange of warranty is my last resort as they will most likely give me a recon set instead of a brand new one like mine , from telco.
Long story short ;
1) my m1 network is always 4/5 bars strong in terms of reception . Never full. At certain places it will go NO SERVICE. Never happen to me when I was using the same SIM card on my note 3.
2) battery. I never download Facebook in my phone . I use it mainly to listen to Spotify and surf the web. No games either. Full charge 100% at 8am. Use it to reply 4 SMSes , surf the net. And reply a few WhatsApp texts. It went down to 97% at 940am. When I first got it 2 weeks ago, this light usage will have the battery stay at 100%. Is there something wrong ?
3) I have been using the Apple iphone supplied charger to charge my phone . However even at 100% for a very Long time , it will still have the Lightning sign. Is it normal? It won't be like my previous ipad where once fully charge , it will auto cut off and lightning sign disappear?
My current iOS is 9.1
Very Glad there is this community here sharing informations on Apple devices .
Long story short ;
1) hardly ever get "no service" in sincity, prob can try changing e sim.
2) have u used e battery settings page to monitor which apps r eating yr battery?
3) e charger supplied in e box only charges at 1A. use a faster charger like e iPad ones...
Yup. Apparently Safari is the highest.
Okay but the normal charger , I charge from 12midnight to morning 6am, despite 100%, still got lightning sign leh. Don't seems correct right?
Apple devices will always display the Lightning sign when they're plugged in. Irregardless of whether the battery is fully charged or not.
Hope this helps!
Hi I have problem logging in to certain website..I key in Username n PW press login but it still bring me back to the login page..
I have tried clearing history n restart my hp but no use still the same..
Before that I m able to log in , it recently that I cant log in but using other hp I can log in be it Iphone or samsung...
Tks in advance
Do you have an ad blocker running in Safari?
No I mean adblocker. Settings, Safari, content blockers.
Hi I cant seem to have this content blocker under settings..
Pls advise tks alot
You need to install a content blocker app from App Store for it to show up in settings. Seeing that you can't access the content block option under Safari settings, I don't think you have an ad-blocker installed?
Hi bro so I need to ON the blocker or ??You need to install a content blocker app from App Store for it to show up in settings. Seeing that you can't access the content block option under Safari settings, I don't think you have an ad-blocker installed?
Long story short ;
