Printer recommendation
nexusRAGER
Looking for a laser printer for use for school.
anyone can recommend? never bought a printer before :o
looking for a laser one that prints colour and has wifi.
budget about $200
thanks!
bunnypangsai
must list your functions. whether you need b/w only, or die die want color. Scan/photocopy fn? wifi printing?
now laser printer cheap cheap. If you want all those fns i mentioned above without color, can get brother HD-2540DW, sub 200 range. Color will be in the 300 range.
nexusRAGER
not sure leh buying for poly. prefer with wifi :o
bunnypangsai
say first ah, the wifi function might as well not have it. Want to print must be SUPER close to the printer itself. -.- but if you're printing through tablet/phone then ok lo.
Do you have an existing color printer? If so, just get a b/w laser printer lo. :)
nexusRAGER
i no printer now :(
find it sibei mafan when want to print things to collect from qoo10 :(
Elijahonli
no lea.... that one u talking about could WIFI Direct or NFC print .... Wifi enabled printers normally connect to the router just like how ur normal phone is connected to ur router. This printers once connected are treated like network printers.
bunnypangsai
orh. oops. but abit useless for me, cos my printer is hidden in the study room while the router is on top of a cupboard, far far away from the study rm.:(
Elijahonli
i no printer now :(
erh i suggest buying lazer honestly, i had like 2-3 inkjets as i rarely use them even during my poly days, the inks always dry up before i can use the 2nd - 3rd time after a fresh cartridge. there are some cheap Mono Lazerjets with wifi function going around 100-150...
sometimes can check out Lazada or Qoo10 as well see if there are any deals.... u can also check out the lazer printer thread.... i bought mine from lazada although it turned out that best denki had offered the same price, lazada's price included shipping and savings from shopback lol..
bunnypangsai
yeap yeap. ink cartridge also quite ex.. long run it's not worth it. duplex printing b/w will be in the upper 150 range.
mosmos
High Honorary Member
if you can wait, wait for the march IT show to buy.
Elijahonli
oh yes, thought i mention are without AUTO-duplex.... some of them will state duplex but its actually manual duplex lol....
WhiteHunter
go there tekan those xdd/xmm selling laptops/desktops or to beo XMMs arh. :s13::s13::s13::s13::s13::s8:
not so sadist like you leh. pc shows the price are generally cheaper for printers and they give alot of free stuffs like black and colour ink cartridges or some printing paper or scanner if you get those high end models.
jeff79
Get the google cloud print enabled wifi printer. Do not need to install driver in PC.
harharhar
FX P225 has auto duplex and wifi options. I'm using it at the moment and it's been good!
Edit: P225 supports google cloud print as well
I also have another one P355 for small-office use. Similar features but bigger, faster speed and lower running cost.
nexusRAGER
think i might need one that prints colour.
Budget around $200
