2017 LG OLED
FLiNcHY
Hmm my 4K 60gb Pacific Rim uprising BluRay remux mkv file can’t play from USB 3 HDD...
Will Synology 218play be able to play it?
FLiNcHY
You stream using DS video or Plex?
Do you think ds218play will suffice?
spectral
Finally went down to mega discount store to mtl a 65c7, was told the that is the last set. They dun even wanna sell me their display set, keep saying display set cannot sell.
moron+genius
TV built in player... TV will detect the NAS as a DLNA server n I just surf to the folder n play the file. Dun need plex but plex got nice UI. DS video is 4 use in mobile devices I believe. I can’t confirm 218 will suffice or not but it probably shld. Y dun u test wif another HD or thumb drive 1st?
FLiNcHY
Yah i also plan to just play on the tv built in player from the NAS. OK i go test another file first then.
forests_gump
LG TV's Ez-Adjust Area code/Area option
Quick check: anyone have experience access LG TV service menu's Ez-Adjust or Area code/Area option?
Anyone aware what Area option/area code did LG used for Singapore?
spectral
Obviously.
Beside the remote there is also an apps on your mobile to replace the remote, if necessary.
I have not receive my c7 yet, so just asking.
Understand that the tv will come with the magic remote which i guess is using RF/wifi/bluetooth of sort.
I am checking if c7 support using normal IR remote which i have a programmable remote which can learn code from IR, so I can use this programmable remote for basic operations (switch on/off, vol, change ch etc..)
ac3knight
After using this series of magic remote, you won't want to use any other remote 😄
Should also have no problem controlling other hdmi-cec devices or media players unless u have non hdmi-cec devices like xbox
reno77
The c7 supports both ir and it's native rf remote.I use my phone's ir as a basic remote to on/off and adjust the vol. And the given remote for the voice control.
morpheus2480
Couldnt find c7 island-wide anymore... went to GSS fair at expo tonight and bought 55” c8 for 2,700 (display unit)
